Thank you for the case number, CAS-1693162-K1Z2L9 is the complaint case number that was escalated by our support team, our supervisor has tried to contact you but failed, and voicemail and email have been sent to you that warranty service cannot be provided after double analysis.
For your two questions, firstly, the drone was disconnected from the APP because the signal was blocked since you flew in heavily forested area. When RTH was triggered and the drone flew back around the home point, you connected the drone with your mobile device instead of RC, the failure of re-connection is related to the relative location between your mobile phone and the aircraft, this cannot indicate the drone has malfunction.
For the second question, the GPS accuracy is of the order of meters, there may be the deviation when the drone landed in home point, therefore, we recommend customer to fly in open area.
According to our management department, the warranty cannot be provided since the craft showed no signs of a manufacturing defect or malfunction, thanks for your understanding.
