Flight data logs
1438 10 2018-4-21
nywrecker
Flight distance : 832421 ft
I exported through the Assistant 2 the flight logs to my local drive.How can I view them?
2018-4-21
marklyn59
Flight distance : 395072 ft
In the assistant folder there is a viewer.exe that you can run to view the files but they're not intuitive so you will be spending a bit of time understanding the data fields/metrics.
I believe in the DJI Assistant app there is also a link to the viewer there.
2018-4-21
nywrecker
marklyn59 Posted at 2018-4-21 06:21
I opened the viewer program and within it I opened one of the .DAT files I had saved locally.
I only got some titles on the right of the screen. See screen shot.
I was hoping to get the CSV files I always see at this forum.
2018-4-21
G_Sig
Flight distance : 9109311 ft
Iceland
nywrecker Posted at 2018-4-21 14:54
I only got some titles on the left of the screen. See screen shot.
The CSV file is mostly from the TXT file on your device.
You can upload it HERE and then download the CSV file from there.
2018-4-21
B1houdini
Flight distance : 927927 ft
G_Sig Posted at 2018-4-21 14:59
G_Sig is right about the CSV files
If you are using an IOS device:
You can go to iTunes , connect to the computer with your iPhone (in my case iPad Mini 4). Click on the iPhone symbol. click on the App sharing file . It will bring up the apps on your phone. Find DJI GO 4 app and click on it and you should get all its files. Mainly the log files and flight records are the ones I look at. Hope that helps?
2018-4-21
nywrecker
B1houdini Posted at 2018-4-21 15:07
Sorry to pester you.
I connected my iPad Mini 4 to my PC, opened iTunes , clicked on the iPad icon but I do not have apps or app sharing.
The only categories I have under Device are Music, Movies, TV Shows, Books, Audio Books, Tones and Purchased.
2018-4-21
G_Sig
Iceland
nywrecker Posted at 2018-4-21 16:45
This should work Log from Apple.
2018-4-21
nywrecker
G_Sig Posted at 2018-4-21 16:53
We are making progress!
I finally was able to navigate through iTunes to the Flight Records folder and saved it locally.
The folder contained many TXT files but when I open them thay only have ASCII characters...
2018-4-21
G_Sig
Iceland
nywrecker Posted at 2018-4-21 17:12
The folder contained many TXT files but when I open them thay only have ASCII characters...[view_image]
Use the link I sent you in post #4
2018-4-21
B1houdini
Hope this helps.
2018-4-21
nywrecker
Finally!
That was awfully complicated.
Thank you!
2018-4-21
