Flying with Trains_Loosing Connection
2188 22 2018-4-21
PedalingDuo
Flight distance : 31896 ft
I went out to practice my flying skills the other day and put this together.
I had an odd thing happen with my Mavic Air.  Everytime a train would come by my connection to my Galaxy S9 Plus would drop in and out.  When there were no trains passing by it was fine.  It didn't matter if I was in 5.8GHz or 2.4GHz, it did it with both.   Does anybody know if the railroad in the USA uses WiFi on the trains or some other stong radio signal in those bandwidths?
Anyway, I had some fun.  Hope you enjoy this short clip.
2018-4-21
sky6105
Flight distance : 345653 ft
Very Cool video thanks for sharing.
As for your cutting in and out problem no idea.
2018-4-21
B1houdini
Flight distance : 927927 ft
Great video.
Sorry to hear about the bad connection on your phone.
Did you loose phone connection itself or lost connection between phone and controller?
I do not think the train frequency's interfered with the drone or the phone.
The railroads of North America are assigned a group of 97 frequencies in the VHF band. These frequencies are in the range of 160.110 megahertz to 161.565 megahertz, in 15 kilohertz increments. Outside the VHF band, the railroads of North America use the frequency 457.9375 megahertz for transmissions from a train's end-of-train (EOT) device to the train's lead locomotive.
Phone frequency  are from 1850-1990 megahertz
2018-4-21
dronist
Very dangerous what you did! Second you need to stay away from metal. You had metal all around you!
2018-4-21
Kevjones1959
Flight distance : 61932 ft
South Africa
Were u using filters on your lens by the way.
2018-4-21
Tomcatuk
Flight distance : 28743 ft
Thats a nice video of trains thanks for the share :-)
2018-4-21
DJI Elektra
DJI Team
Hi, there. I would recommend you fly in a recommended environment. Voltage line can have a bad influence on image transmission. Please change a place without interference and see if the performance goes well.
2018-4-22
PedalingDuo
B1houdini Posted at 2018-4-21 18:25
Great video.
The symptom was, the picture on the phone would freeze. The drone still responded. And it seemed to happen only when the train went by and it was very intermittent. If there were no trains the picture was fine. And it only affected the phone, the video on the SD card in drone was fine.
2018-4-22
PedalingDuo
dronist Posted at 2018-4-21 19:59
Why would you consider this dangerous?  The only issue that I had was the occasional freezing of the image on the phone, and that only occasionally happened when the train passed. The drone flew just fine.
2018-4-22
PedalingDuo
Kevjones1959 Posted at 2018-4-21 23:36
Yes, I was using 16 ND filter.
2018-4-22
PedalingDuo
DJI Elektra Posted at 2018-4-22 02:01
The mavick air did fine. The environment was OK. The only odd issue was when the train would come by. The drone did a great job I am very happy with its performance.
2018-4-22
PedalingDuo
Great video.
Oh, and thanks for the info on the frequencies that the railroad uses. You seem quite informed.
2018-4-22
B1houdini
PedalingDuo Posted at 2018-4-22 04:21
Did a little more research.
Todays trains are mostly diesel and drive large electric generators that can produce  an EMI, Electromagnetic Fields and Electromagnetic Interference.  It is possible that your devices are more sensitive then others and act like you see it on occasion.
My advise is don't fly near trains. And take the advise from DJI Elektra.
Let us know if the problem goes away.
Fly safe.
2018-4-22
Kevjones1959
South Africa
PedalingDuo Posted at 2018-4-22 04:03
Very nice, really like the saturation.
2018-4-22
PedalingDuo
Kevjones1959 Posted at 2018-4-22 08:42
Thank you for noticing the color
2018-4-22
dronist
PedalingDuo Posted at 2018-4-22 04:01
Did you read DJI Electra response???
Train is metal. Tracks are metals. Probably you took off next to your car.
Second you are flying over a run away train between track signal supports which are also metals
2018-4-22
DJI Elektra
DJI Team
PedalingDuo Posted at 2018-4-22 04:04
It is great that your drone act well in the flight. But I still recommend you fly in recommended environment. Please do not risk your drone and happy flying.
2018-4-23
Vidjcb
Flight distance : 17773858 ft
Well, I just want to say metal is not good for MA. Good metal for me is the one related to music
2018-4-23
Montfrooij
Flight distance : 2845026 ft
My best guess is just the amount of metal that was the problem.
Did you also have it when flying higher in the air?
2018-4-23
PedalingDuo
Montfrooij Posted at 2018-4-23 04:46
No  the interference came only when the engines came by and only with some of the engines not all, otherwise everything was fine metal and all
2018-4-23
Montfrooij
PedalingDuo Posted at 2018-4-23 05:20
Ok, so there was something different with these engines.
I'm no tech guy so that is difficult for me to explain.
Maybe some radio the operators have that caused the interference.
Or maybe the wagons were equipped with an RFID tag.
Although I doubt they have so much power.
2018-4-23
PedalingDuo
Montfrooij Posted at 2018-4-23 06:13
This was from one of the members here.
2018-4-24
Montfrooij
PedalingDuo Posted at 2018-4-24 07:22
That might be it.
Still strange you only had it every now and then
2018-4-24
