Does Fire HD 6 Compatible with DJI apps ?
4370 9 2015-5-9
hanracing
Singapore
2015-5-9
bvinisky
Natively, no. But you can side load the app. I used a fire hd 7 until they released for IOS.
2015-5-9
imdjay
Flight distance : 194541 ft
bvinisky@gmail. Posted at 2015-5-10 05:23
how well did it function?
2015-5-12
bvinisky
imdjay Posted at 2015-5-13 10:45
It was functional in a pinch, but performance was fairly poor in my opinion. The image would stutter frequently.
2015-5-15
barleydave
Flight distance : 80810 ft
Hi, I'm thinking of buying a Fire HD 7 for use on the Phantom 3 App.  Are you saying you have this working?  Did you have to root the device (I'm happy to do this).
2015-5-27
bvinisky
barleydave Posted at 2015-5-27 20:32
Hi, I'm thinking of buying a Fire HD 7 for use on the Phantom 3 App.  Are you saying you have this ...
Yes, it was working for me at the time, but I haven't used it since the first week of launch. Since it wasn't going to be my primary device I didn't bother spending too much time trying to get better performance out of the video. Reducing the streaming quality and bandwidth used might help with the stuttering, but I would go in assuming you're not going to get seamless video performance out of it. Depending on your needs, you may be able to find a better performing tablet in the same price range too, so make sure to research.
The general process for loading the app was pretty straight forward and quick. I didn't have to root the device. In the settings I enabled the ability to install applications from unknown sources (non-Amazon app store). I then installed an app for file management (ES3) and proceeded to download the Android app directly from DJI using the tablet. To install the app, I located it with the file browser and just opened it. If you google kindle fire hd side load, you should be able to find a number of tutorials with more details.
2015-5-27
lpolanco
Flight distance : 375177 ft
Dominican Republic
it is not working for as of now. the connection to the RC via USB is not detected by the tablet
2015-10-3
keats2kool
Flight distance : 1248484 ft
lpolanco@kanter Posted at 2015-10-3 16:34
I'm having the same problem with the Kindle 7, did you ever figure it out?
2015-12-6
lpolanco
Dominican Republic
keats2kool@gmai Posted at 2015-12-6 16:57
Yes, I did figure it out! it has to do with the USB permissions on the tablet, I downloaded an application that did the trick for me, it resulted in a very unstable connection so I just bought a refurbished Samsung Galaxy tablet for under $120 that performs really good!!
2016-1-29
MRF1967
Flight distance : 236 ft
I wish I had seen this before I bought the Fire HD 8. The work around sounds very technical. I was naively thinking I'd just load DJI Go 4 and be off having fun. Grrr
2018-1-26
