Thanks for the patience, I have confirmed with the team, per the flight records shown the APP, the home point was recorded with strong GPS signal. If you believe the home point is wrong, please provided us more evidence like video and so on, we will forward to the team for further analysis.
At 0:08, the GPS became weak, you said the aircraft appears at first at the wrongly recorded Home Point, and then appears next to the position of the controller from 0:07-0:08. Since the weak GPS signal, the coordinate is empty, therefore, the flight record was jumped to the next coordinate that the GPS signal recovered. Please note at 0:08, the distance has become 94.6m, and during 00:08-00:25, you kept fully pushing the joystick forward until 00:25, the GPS signal got strong, which means the position of the aircraft was changed because you kept pushing the drone forward instead of there is malfunction with the drone.
At t=02:28, h=79m, d=108m, the aircraft triggered the RC LOST RTH, pilot set the return height 30m, the aircraft started to RTH with the current height, the flight record interrupted at t=02:30, h=79m, d=106m.
I think currently, your concern is that the home point is different from the place where the drone took off, but per the flight records, this point cannot be verified unless you provide more evidence, we have provided the best offer in this case, hope your kind understanding.
