Paco572
With only my second flight for my spark, I only wanted to go straight up and then back down. Had good IMU and compass, 15 Satellites, fully charged up, 5.4ghz wireless good, crystalsky 5.5 took it up to 300ft, then lost connection. Aircraft took off away from me at full speed, directly into the sunlight, lost sight of it, hit RTH, didn't work, hit again on the screen didn't work. Last ditch effort, held the joystick in down position to at least try to bring it down before it hits something or somebody, Eventually, I saw my spark off in the distance the controller regained connection I was able to bring the AC down but RTH didn't function. Made it back with less than 8% battery. Isn't the AC supposed to enter RTH if it loses connection with the controller? I'm absolutely terrified to take it up again. This is such BS. It should never happen, but apparently, it happens all the time from what I've read here. DJI when are going to fix this "FLY AWAY PROBLEM"?
Disappointment is beyond belief,
PACO
