info Waypoint mode is supported by all DJI drones except Spark.
Litchi's Waypoint mode allows you to setup classic waypoint missions as well as advanced camera moves such as Selfies and Cable Cams.
Place multiple waypoints on a map however far you want and the aircraft will fly from waypoint to waypoint and complete the mission even if the signal is lost.
The maximum aircraft speed in this mode is 15m/s (no wind).
Regaining ControlWhenever the drone flies autonomously, you can regain control instantly at any time using the remote controller's flight mode switch.
For newer drone models (Mavic Air/Pro, Phantom 4, Spark, Inspire 2), toggle the flight mode switch from "P" to "S"(sport) mode in order to regain control. You may switch back to "P" mode afterwards.
