Genghis9
Just my opinion, but I've been convinced for some time now that a lot of the plastic parts DJI uses is substandard and does not have the integrity to hold up to the use it gets. Either the subcontractor DJI uses is going cheap on the product or the QA standards are lacking or non-existent. Either that, or DJI is doing so under their own manufacturing process. I can't believe that they can't produce a plastic with more flex and has the ability to absorb the vibrations, heat, and use they get, while keeping the weight low.
In the case of these batteries, it may be the heat they generate that is causing the breakdown (assuming they have not been dropped or involved in a crash).
Best it appears anyone can do is glue it, IF the cells themselves have not gone bad.
Fly Safe!
