Broken... what part do I need to replace?
1840 10 2018-4-24
cjnaz
I haven't disassembled the AC yet.  This tab provides a stop for the left rear motor arm.  Its fractured and doesn't provide a firm stop.  What part am I look for?
2018-4-24
DJI Diana
Flight distance : 2408 ft
Hi there, I'm sorry to hear about the issue, it is not recommended to disassemble the drone yourself, please kindly contact our support to start a case and send it in for diagnoisis: https://www.dji.com/support. Thanks!
2018-4-24
cjnaz
I'm adventuresome. and generally capable for this sort of work.  I also accept responsibility for my mistakes.  So what part am I looking for?
2018-4-24
qenddrimgashi
Kosovo
I'm sorry to hear this problem. I think you should go to dji website and they will help you
2018-4-26
cjnaz
Thanks folks.  A new rear arm is on order.  I'll reply after the fix.  I'll also look at how this might be beefed up.
2018-4-26
cjnaz
Replacement arm went in smoothly.  Back up and running.  This "shoulder" plastic piece looks like the weak link.  It a small plastic piece that surrounds the hinge of the arm and breaks easily on a crash.
2018-4-29
dronybaloney
Flight distance : 24897940 ft
I had a very small crack in this piece. I superglued it aswell and had no problems, its very solid again
2018-4-29
dronybaloney
And i read somewhere that you can even fly without , that this shoulder is not the part which stops the arm from getting up. The armspring will not go up further anyway
2018-4-29
cjnaz
On mine the arm could be rotate further up.  No firm, solid stop.  I think this resulted in the AC flying a little cockeyed and my pictures had a couple degree tilt to them.
2018-5-2
HedgeTrimmer
cjnaz Posted at 2018-4-26 09:06
Please do.  Be interested in how hard it was, special tools, and if any problems flying afterwards.
Updated: I missed this post --- Replacement arm went in smoothly.  Back up and running.
2018-5-2
cjnaz
Easy enough if you can open a phone and solder.  Biggest problem was trying to get the two case clips in the front to release.  YouTube has all the clues.
2018-5-2
