Genghis9
US FAA requires VLOS, technically, because of that restriction it does not sound like you can use that app in the states either. Also, the P4P does not have more than about a 2 pound payload capability (not much) and depending on how it is carried it can cause a lot of stability issues that can result in a crash.
FYI - the state of NY has established a "drone" corridor that is about 75 miles long for R & D, and it is being used for testing things like this. However, you still need FAA waivers for this and even the autonomous drones must be monitored by some means in order to establish override control in case there are problems. I believe other states are looking to establish similar areas for testing research purposes too. |
