Update 2 Analysis program
986387 986387 2018-4-25
Spark_Pilot_XxXx
Flight distance : 67841 ft
hey ,yeah seems like that log was to old... with a newer one it works!
2018-10-15
Spark_Pilot_XxXx
just one question.... when i click on go home summary there it says mismatch.which mismach is meant by that?
2018-10-15
Spark_Pilot_XxXx
and what does moving heading mean?
2018-10-15
JJBspark
Flight distance : 12225059 ft
Spark_Pilot_XxXx Posted at 2018-10-15 09:11
Hi,
When RTH becomes active your drone is first turning to the home direction and fly that heading to home.
Mismatch is between the heading to home and the actual moving heading.
If all is OK there is no mismatch, well withinh few degrees is normal.
like this one....(spark data is the heading the drone is facing, to home is the heading it should go to gohome and actual is the moving direction the drone is actual flying!)
cheers
JJB
2018-10-15
JJBspark
Spark_Pilot_XxXx Posted at 2018-10-15 09:44
Moving heading is the actual move direction of the drone.
With zero wind and only fwd pitch they are the same ; drone facing a heading and drome moves that heading.
Flying at lower speed drone moving heading is not always the direction of the nose....
(if ofcourse only fwd pitch is applied, only roll means 90 degrees offset of the nose heading)
cheers
JJB
2018-10-15
Spark_Pilot_XxXx
Thank you! Very nice program!
2018-10-15
Spark_Pilot_XxXx
So if the moving heading is different from the spark data heading the drone is not flying straight?
2018-10-15
JJBspark
Spark_Pilot_XxXx Posted at 2018-10-15 11:46
The heading in the main screen is the heading of the drone, so the direction of the nose pointing.
If the moving headin is not the same it does say something....but difficult to analyse cause its a complex of items who causes this. (input stick, wind, turbulence. yaw/imu mismatch maybye, etc etc)
If you see a lot of flights (preferable your own cause you know what happend) you get a feel to interpret this data.
Its usefull to see a RTH into heavy wind! Drone heading is OK to gohome, but moving dir is 180 the other way....
cheers
JJB
2018-10-15
Spark_Pilot_XxXx
Okay thank you! Another question: is current the motor output?
2018-10-16
JJBspark
Spark_Pilot_XxXx Posted at 2018-10-16 10:16
nope, not all GO4 app version record the current for the the motors, so its a amperage value
2018-10-16
Spark_Pilot_XxXx
Sorry ,what ist an amperage value???
2018-10-16
JJBspark
Spark_Pilot_XxXx Posted at 2018-10-16 11:22
Oops, uh   U = I x R   > voltage = ampere x ohm.  if this doesnot ring a bell, do some googling
2018-10-16
HedgeTrimmer
JJBspark Posted at 2018-10-16 11:41
A picture is worth a few words
V = Volts
P = Power (Watts)
I = Current (Amps)
R = Resistance (Ohms)
2018-10-16
Spark_Pilot_XxXx
Oh,okay! Thank you!
2018-10-16
JJBspark
HedgeTrimmer Posted at 2018-10-16 11:49
http://www.ohmslawcalculator.com/static/img/ohms-law-wheel.png[/img]
thanks! will keep this for my kids
2018-10-16
JJBspark
Hi FRAP users,
Version 3.9 is alive.  see post #1
cheers
JJB
2018-10-17
Goody
Flight distance : 102470 ft
Czechia
Well done
Now I have a fantastic toy to spend the time to deeply analyse my flights Cool!!!
2018-10-25
JJBspark
Goody Posted at 2018-10-25 05:16
Well done
Hi Goody,
Thank you, enjoy my FRAP !
And still busy and adding things to FRAP,  i have seen a flightrecord with more than 12.000 records! (wich i now my limit, see if memory can deal with more)
cheers
JJB
2018-10-25
bbloomquist
Flight distance : 878852 ft
Nice work on the program!
2018-11-7
MAPilot
JJBspark Posted at 9-3 11:54
Hi BumblerBee,
Thanks! can you make a screenshot what you exactly mean? Sent it to JJBsoftware@gmail.com please.
This seems to be a fantastic program.  Is it freeware? shareware?  Is there a website that describes it?
2018-12-4
HedgeTrimmer
MAPilot Posted at 12-4 19:08
If you are referring to JJBspark's FRAP, it is Freeware.   JJBspark has been very kind to provide his program without charging for downloading and using it.
2018-12-4
JJBspark
Hi MAPilot,
Just download and start to use it. If any questions just ask me (here of via email [read in FRAP] ).
Program is kind of self explaining, just click all buttons and see what happens  :-)
cheers
JJB
2018-12-4
HendrikJB
Flight distance : 2132792 ft
South Africa
Hi there the link was removed (looks like it was automatically removed).
Please send privately.
2018-12-6
AMZPOW
a nice tip post, thanks for sharing
2018-12-7
JJBspark
AMZPOW Posted at 12-7 01:44
thanks, if any questions  just ask
2018-12-7
towheaded-pilot1
Flight distance : 35125 ft
Downloaded. Will give it a try as soon as I get a chance.
2018-12-10
MavSpa_user
Flight distance : 73209 ft
Thanks for the update
2018-12-11
MAPilot
JJBspark Posted at 12-4 23:41
Hi MAPilot,
Thanks.  I'll give it a go.
2018-12-24
djiuser_98iOlrpXzokk
Is this open source as I am a UI designer and was wanting to build a better looking UI for it?
2019-1-10
2019-1-10
Skeeter Honey
Flight distance : 1032569 ft
JJBspark, you're an electronic artist and a gentleman.  Thank you for this!
2019-1-10
JJBspark
djiuser_98iOlrpXzokk Posted at 1-10 17:04
Nope. its not open source software.
And i am happy with my UI
cheers
JJB
2019-1-11
JJBspark
Skeeter Honey Posted at 1-10 17:36
Hi Skeeter Honey,
Thanks. but i am just an engineer with some time consuming hobbys....
Gentleman......well, uh  yes but not always.
cheers
JJB
2019-1-11
JJBspark
Hi all,
See post #1, update FRAP version 4.4
cheers
JJB
2019-1-14
MavSpa_user
Thanks for the Update JJB
2019-1-14
JJBspark
MavSpa_user Posted at 1-14 10:11
thanks. if the polar chart gives an error than download the zip file again. (stupid me, forgot something to enable ; same version but fixed that)
2019-1-14
MavSpa_user
i have something else, in google earth I cannot use basic kml, i get error gpx file not found
2019-1-14
MavSpa_user
and when I start the program:
2019-1-14
JJBspark
MavSpa_user Posted at 1-14 11:07
is this checked?
2019-1-14
JJBspark
MavSpa_user Posted at 1-14 11:11
[view_image]
oops, never seen that before.....and the program starts ok after this message?
2019-1-14
