(SPARK) Aircraft is locked
4304 38 2018-4-27
bidsinga
Hello,
Last week I bought a Spark drone. I charged the battery, started the drone, installed the app, installed the DJI assistent 2 on my desktop, connected my android to the drone, updated the firmware. All things seemed fine, till I got a messgae saying that the "Aircraft is locked". I tried many things so far, but nothing helped. I read all kind of forum treads, downgraded my firmware and updated it again, reinstalled the app. I'm starting to become a bit desperate. I haven't used the drone for a single second and it seems that there is a lack of information about how to solve this problem. I hope someone can help me out in here. Thanks in advance.
2018-4-27
bidsinga
I also used "factory reset settings" and I calibrated the IMU and compass.
2018-4-27
A CW
Flight distance : 13978875 ft
Have you updated the precise fly database within the app for DJI GEO to know your location?
2018-4-27
bidsinga
A CW Posted at 2018-4-27 02:14
When Im connected to the drone it says that I need to connect to internet and when Im connected to internet is says that I need connection with the drone. The current version is 01.00.01.09, so I guess that is the latest version.
Btw, my drone is unlocked thanks to the duml dore program, but somehow it doesn't feel like the right solution.
2018-4-27
A CW
bidsinga Posted at 2018-4-27 02:31
OK - that is the latest FW version. Have a look at the DJI tutorial on the whole set up process for linking and updating FW and see if that helps.
2018-4-27
Riks
Hi have the same issue as well, I've updated everything, AC BATT RC, whit djigo4 and djiassistant 2, i've looking on the web for somethings to do, i' ve speaked with the dji technics, but nothing the only thing they say, it's to send back the drone... it's possible there is no a fixing way we can do for fixing this f...g problem?... i've updated all the precise fly database, sorry for my bad english... i'm waiting some fix, please if someone fix this problem let us know more
2018-4-27
Hi bidsinga, sorry for the troubles, could you please provide the files under /sdcard/DJI/dji.go.v4/LOG/CACHE/UP_NEW_ALL and the serial number for further analysis?
2018-4-27
Riks Posted at 2018-4-27 05:31
Riks, may I know if you are using Android mobile device? If yes, could you please refer to my post in 7# and provide us more info? Thank you very much.
2018-4-27
S-e-ven
Flight distance : 5922034 ft
Thailand
With google and 'DJI Spark locked', you could find a video with the chance for a solution.
2018-4-27
bidsinga
DJI Mindy Posted at 2018-4-27 20:06
The LOG map seems empty.
2018-4-28
bidsinga
DJI Mindy Posted at 2018-4-27 20:09
Yes I use an android
2018-4-28
S-e-ven
Thailand
Do the firmwareupdate again, but use the PC and DJI Assistant 2 instead!
2018-4-28
djiuser_4t5xsJIOZEzD
Flight distance : 19265 ft
Austria
Same problem here... Aircraft locked. All the APK and firmware is the latest and newest. All function works but the copter cant take off due its locked.....
2018-4-28
Johlianto
Indonesia
I have exactly the same trouble,, Aircraft is locked,, and there is no key to unlock the aircraft.. what we should do? I tried hundred times to scan the QR code, but it keep telling me this,,
2018-4-28
bidsinga Posted at 2018-4-28 00:38
Thanks for your feedback, we are collecting more info from other users, I will keep you update if there is any finding, we are so so sorry for the trouble caused.
2018-4-28
djiuser_4t5xsJIOZEzD Posted at 2018-4-28 01:34
Sorry for the difficulties, we care much about your feedback, may I know if you use Android mobile phone? How about trying iOS device? For Android mobile phone, could you please provide us the files under /sdcard/DJI/dji.go.v4/LOG/CACHE/UP_NEW_ALL and the serial number for further analysis? Thank you very much.
2018-4-28
Atheist1985
Exactly the same problem here... New Spark... Not usable...
2018-4-28
hg87
Flight distance : 117123 ft
Do you by any chance have an RC as well? If you do scan the controller not the aircraft.
2018-4-28
DJI Susan
Atheist1985 Posted at 2018-4-28 04:26
So sorry for the inconvenience. I understand how frustrated you are and we still need more data to check the exact status. Please kindly offer the below info at your convenience, we'll try our best to help you out.
1. Please kindly offer the aircraft SN;
2.  Which mobile device do you connect? Android or IOS? Does the issue remain if changed to another OS? Please kindly offer the log from here:
Android: /sdcard/DJI/dji.go.v4/LOG/CACHE/UP_NEW_ALL and /sdcard/DJI/dji.go.v4/LOG/CACHE/UP_DATA_ALL
IOS: log/upgrade0
3. Make sure the internet is connected and update the flysafe data to the latest version.
4. Please kindly refer the tutorial video and export all data(including the flight logs and black box) for analysis.
Thank you so much for your patience and understanding.
2018-4-28
Atheist1985
The post does not meet the required size. Current size: 882042 bytes System limits: 10 to 100000 bytes
2018-4-28
Riks
this directory it's empty for me, and I use android device... samsung galaxy a5 2015 i know i have to change phone.. i will do in this day
2018-4-28
Hi all, our engineers are working on this issue in high priority, if you have exported the log, please kindly upload to Dropbox or Google Drive and post the link here.
It would be much appreciated if an IOS mobile device can be used to have a try? Please connect the phone to the network, enter DJI Go 4 APP, if there is pop-up window about the Fly Safe Database upgrade, please update to the latest version and then switch to Android mobile phone to see if the issue persists. Thank you very much.
2018-4-28
judgemstr
https://www.apkmirror.com/apk/dj ... droid-apk-download/ use this as the current apk is broken. I had the same error and reverted to this version and was able to fly.
2018-4-28
Ooiks
Singapore
Hi my google drive link to my log data is below.
I am using android version 7 on Huawei mate 8.
Serial number is 0ASDE871C100MW
https://drive.google.com/file/d/1vApv7GhYCWA0YGlRovrtBPAaVQL94rqv/view?usp=drivesdk
2018-4-28
Ooiks
Singapore
DJI Mindy Posted at 2018-4-28 19:29
Hi my google drive link to my spark log data is below.
I am usung android version 7 on Huawei mate 8.
My serial number is 0ASDE871C100MW.
2018-4-28
Ooiks
Singapore
Sorry do  not use the above incorrect link. Pls use below link instead for my log data.
https://drive.google.com/open?id ... UGsoRtn1Fr9RQ9HkYsf
2018-4-28
Ooiks
Singapore
Sorry pls use below link instead. the previous link is incorrect.
https://drive.google.com/drive/folders/1GsnCAhpTJyV1JUGsoRtn1Fr9RQ9HkYsf
2018-4-28
bidsinga
S-e-ven Posted at 2018-4-28 01:15
Already did that a few times
2018-4-29
S-e-ven
Thailand
Try this:
https://forum.dji.com/thread-146101-1-1.html
2018-4-29
Ooiks
Singapore
bidsinga Posted at 2018-4-29 01:39
https://www.apkmirror.com/apk/dji-technology-co-ltd/dji-go-4/dji-go-4-4-1-15-release/dji-go-4-for-drones-since-p4-4-1-15-2-android-apk-download/
Try the above link.uninstall ur current Dji Go 4 app and install the version from the link. It has worked for me and a few ppl who have experienced the same problem.
2018-4-29
djiuser_Kf4iPA3DtL3S
Flight distance : 510968 ft
Israel
are you all on 4.2.12?
Did you use the official release in Google Play, or one from somewhere else e.g. apkmirror?
2018-4-29
Jamaboy007
Flight distance : 15659 ft
Sweden
Fixit Now i have same problem, i need to get a old app.
2018-4-29
S-e-ven
Thailand
Jamaboy007 Posted at 2018-4-29 05:59
2018-4-29
DJI Susan
Hi All,
Thanks for your patience. Our engineers have been aware of the issue and will optimize in the next APP version. At this moment, please switch to IOS version or previous Android APP to figure this out.
Again, we sincerely apologize for the inconvenience. We'll release as long as the new version is ready. Appreciate your understanding.
2018-4-30
iheaven
Russia
DJI Go 4 downgrade to 4.1.15 helps I spent 3 nights in firmeare upgrades and downgrades. But nothing... Only DJI Go downgrade soles this.
2018-4-30
mvmv19966
Switzerland
judgemstr Posted at 2018-4-28 21:09
https://www.apkmirror.com/apk/dji-technology-co-ltd/dji-go-4/dji-go-4-4-1-15-release/dji-go-4-for-drones-since-p4-4-1-15-2-android-apk-download/ use this as the current apk is broken. I had the same error and reverted to this version and was able to fly.
Thanks a lot - that solved my problem! I tried everthing, but only this downgrade to a previous DJI GO Software Version helped and i can fly again.
2018-4-30
tonyzero
I'm so glad I just found this post, brought a new spark at the weekend and haven't flown it yet as I keep getting "aircraft locked" I'm on Android as well on a Samsung galaxy S8, kept getting 4 solid red lights and that's it, funny thing is if I reinstalled the firmware I get the 2 red lights and 2 flashing lights but as soon as I reboot it's back to 4 red again.
2018-4-30
DJI Susan
Sorry for the late response. This issue has been figured out in 4.2.14, please update to the latest version and check again.
2018-5-7
iheaven
Russia
4.2.14 works ok
2018-5-11
