FanOfFlight
Flight distance : 1983760 ft
DJI Mindy Posted at 2018-4-28 03:12
Hi there, the firmware upgrade function of the batteries is still not available at the moment, please note the future release.
For the discharge function, it doesn't mean the battery station can charge the battery to 25 or 50 percent and then stop, it can only discharge the battery to the storage mode, for example, if the current level of your battery is 50%, if you toggle the switch to the 50% option, it will not discharge either charge, please check more details in user manual. Thank you.[view_image]
Thanks for the reply.
I understood the discharge to storage level system then. Its just that in other systems like this the charge will take a battery from any state 5% to 100% and charge/discharge to the desired state for storage. The user just says to put it into storage mode.
You system means at the end of the day, you have to charge your battery, and if you exceed the target, you then have to switch it over to discharge it.
I think the engineers should consider the approach the other chargers are using.
and when is the battery firmware capability update coming?
