Hi my week old mavic pro wont fly in a straight line, it flys diagonally to the left, i have treid everything like IMU calibration, compass and RC
any advise? it also shoots to the left when coming to a stop i have included a video the end also shows the flight data
You have to remember testing solow to the ground will not always be a good test, your Aircraft is using VPS at this height which needs good textured ground underneath for optimum lock.
You need to take Aircraft above VPS height to get proper test.
You also need to have done a cold IMU on a very level surface and you should always use a spirit level to check this.
hallmark007 Posted at 2018-4-28 09:53
does it at altitude also i have tried a cold IMU calibration
Dose the MP hover in place.
It could be one of your props is out of balance or one of the motors is not spinning in sync with the others.
Here is a way to check for prop out of balance.
ive tried 2 sets of props sorry i should of said, also it hovers fine, when you fly it towards you it looks like the front left propellor (front right as your watching it come towards you ) is dipped down at an angle
