Custom Colour Settings Have Changed
626 12 2018-4-29
fansdb6ff1f7
Flight distance : 1998786 ft
Anyone noticed that the order that the Contrast/Sharpness/Saturation appear in custom settings have changed following the latest F/W release? They're no longer in the same order as before and are different to the P4P UI. Therefore a custom setting of 1,3,1 on the I2 means an entirely different config on the P4P. (Ipad Mini4).
2018-4-29
fansdb6ff1f7
Custom Colour Sharpness Settings Disabled
Since the latest firmware release the sharpness setting in Custom Colour has moved to the centre. Also changing from minus three to plus three has no effect so it appears to have become disabled. Anyone else getting this issue? (I2/X5s/h264/MicroSD/Ipad mini 4/Latest DJIGo4)
2018-5-1
fansdb6ff1f7
Also ...The sharpness setting is not working. Plus 3 looks the same as minus 3.
2018-5-1
fansdb6ff1f7
Just bumping this post for the attention of DJI as it's causing me a lot of issues. Every custom sharpness setting I'm setting looks like plus 3. All footage on all sharpness settings is massivly crisp. The sharpness setting has also been moved in custom (Its now Contrast/Sharpness/Saturation) and I'm not sure if this issue is connected. Can anyone with an I2 and a Ipad mini 4 check this for me? It used to be Sharpness/Contrast/Saturation ... Still is on my Phantom 4 pro.
2018-5-1
fansdb6ff1f7
Custom colour sharpness settings disabled after new FW
fansdb6ff1f7
Flight distance : 364727
2018-5-1
We have been aware of the order issue and will get it fixed in the future APP release. But for the sharpness setting is not working, have you tried to reset Camera Settings or re-install the APP to see if the issue persists?
2018-5-4
fansdb6ff1f7
DJI Mindy Posted at 2018-5-4 03:04
Hi Mindy. Just got back from taking some stills. The custom setting is not working. Even at -3,-3,-3 in True Coour profile the image is saturated and at maximum sharpness. I reinstalled the new version of Go4 and reset the camera. Please advise ASAP as I have a job at the end of this week. EDIT. The Raw DNG files appear to be OK.
2018-5-5
fansdb6ff1f7
Hi Mindy .. Update. I've reset the Ipad Mini 4 to factory settings and reinstalled Go4. This did not work. All custom sharpness settings do not work. All sharpness settings look like plus 3.
2018-5-6
fansdb6ff1f7 Posted at 2018-5-6 23:58
Sir, I'm so sorry for the late response, I have iPad Mini 4 and the issue didn't happen, could you please provide us one original picture so that we can escalate the issue to the related engineer for further assistance? Just to clarify one the thing, Sharpness, Contrast and Saturation all cannot be customized right?
2018-5-10
fansdb6ff1f7
Hi Mindy. Only sharpness is affected. Contrast & saturation are ok
2018-5-10
fansdb6ff1f7
DJI Mindy Posted at 2018-5-10 02:42
Hi Mindy I flew again today and sharpness setting in custom settings is still not adjustable. Has anyone else reported this issue? This is in video mode. DLog.
2018-5-12
fansdb6ff1f7 Posted at 2018-5-12 08:41
Is there any sample footage can be provided?
2018-5-15
fansdb6ff1f7
Hi. I've just tried with my Iphone 6plus on the P4P and the result is the same so there is a problem with the Go4 app.  Adjusting the sharpness option in custom colour settings using DLog does not change the sharpness. Is there is anyone else on the forum who could check this? (h264, microSD, X5s, Oly glass, Dlog)
2018-5-20
