Matthew Dobrski
Flight distance : 1831050 ft
alexjfinn Posted at 4-24 15:21
Hi there, I have this exact issue with my I2 with X5S. It retracts 85% of the way when landing.
If i remove gimbal, enter travel move and come out of travel move it extends all the way down 100%.
As a temporary (or permanent) workaround you may try manual landing gear operation, as any pilot of manned aircraft will do. Disable automatic landing gear feature from within DJI Go 4 app and use RC lever to raise and lower the gear. After un-toggling "Disable landing gear lock", remove props and gimbal, lift the drone by GPS housing on top and rise landing gear up to examine and - eventually - lubricate the worm gear. Repeat rising and lowering few times manually, observing servo motor performance for smoothness. |
