Riff Raff
Good gracious, I finally got over my stumbling block with controlling the camera tilt with the new gimbal. I was going crazy trying to figure out why the gimbal would power up and stabilize OK, but the camera would not respond to the tilt up/down commands from the Vision app.
Since the camera tilt is controlled through the cable that connects to the new yellow wire, I double checked to be sure that it was connected properly, and it was. Then I separated and reseated the yellow wire connector and the Phantom 2 gimbal control cable, and Voila! I can now tilt the camera up and down using the Vision app. I just needed to reseat the connection.
Since I had never seen it work, I thought that perhaps I misunderstood and that I would lose the option of tilting the camera. That is why I kept asking you about the ability to tilt the camera, Crash. Since you confirmed that the tilt still does function, that gave me the assurance that something was still wrong with my installation. From there it was a matter verifying that I hadn't mucked up the configuration, and double checking the wiring/connections for the tilt function.
I didn't get out to fly yet because I wanted to resolve this tilt issue first. I feel better now that the gimbal is installed and everything is working properly. This gimbal is a pretty decent value if it works like they say it does. Hopefully I will get a chance to fly the Phantom 2 with the new gimbal Monday afternoon and post some video. |
