RodrigueElHajj
Flight distance : 17264 ft
dorbsz Posted at 2018-5-1 17:40
ok, so I calibrated IMU and compass and tried it again, still drifting like the footage. I then tried CW's suggestion on refreshing FW thru Assistant 2, recalibrated IMU, controller and compass and now it is much better than the footage however I can still tell it drifts like that in certain occasions which are not related to wind (drifting against the wind actually). I'll upload some footage to demonstrate soon. This only happens when the drone flies forward, when it flies backwards it never drifts. My DJI Phantom 3 standard never did that, so I'm suspecting there's something wrong with this unit.
I had the same issue couple of times before but sometimes it happens and others all works great, even the huge drigt when U stop the drone, but I think this is depending on where u're flying , if the ground patterns aren't contrasty for the censors or if u're in ATTI instead of GPS of even if the SATs Locked aren't enough.
Before U fly let the drone hover a bit and Make sure u're In GPS mode, Sats are 12 and above and away from all interference areas and try again.
EDIT: When u Calibrate the IMU and compass make sure u don't do it on concret , I think grass is a good place for this away from metal objects
