Kevin James ÓBrien
Flight distance : 1788297 ft
First off. You cannot update the P4P Controller via Dji Assistant 2. It has to be done using the Dji App. Don't worry, it's so easy I did it. The two photos i posted are in the wrong order. Firstly long press on the three horizontal lines in the top right corner of the screen. This should bring up the second screen in which you choose your firmware. Hopefully problem solved. |
