Bashy
Flight distance : 2354357 ft
IF you are already on the 2.4ghz and only getting 2500ft max when out in wide open space, then make sure you are on the latest firmware, there was one of the firmware updates a while back that really restricted distance for whatever reason, i could only manage max 1000m with parabolic and about the same as you without one, i was then put on to the .301 beta for a gimbal issue and the P4P had its distance back, it would do about 2600m, think it topped out at 3100m one clear, windless winters day. so, as said above, make sure you download the latest DJI Assistant 2 from the p4p specs page or download direct here (for windows), then turn on the controller, then connect p4p to the PC/lappy and then turn on the p4p, then open DJI Assistant, the process order is only important when turning on the RC 1st, the rest do in what order you like, good luck and let us know
DJI assistant for Mac
The above links are direct from DJI, i added then for you just for ease, just hover over a link to see where they lead, should show you at the bottom of the browser
