RMJovo
Flight distance : 1716240 ft
KedDK Posted at 2018-5-1 07:02
Yes they are sneaky those lines and impossible to see on the video feed even when it is known they would be right there, good to hear nothing was harmed.
I usually fly to one of the poles/masts and with the camera pointed straight forward go up until it pass a little by the top wire, then i know at what minimum altitude i can pass safely between the poles without trouble when going for the actual shot. almost same procedure for passing below the lines, then just have in mind that often they hang down in the middle specially on hot days.
Good advice, I will try this next time i’m In that area. Thanks much for this common sense idea I should have thought of Thanks again. |
