CrystalSky 5.5 Offline Maps?
AndyThilo
Flight distance : 9186 ft
Hi
Just received my 5.5 CS. However I see no option to download offline maps? I've started Go 4 and under the 3 dots there's no option? If it's not available, I assume I can cache if I'm connected to Wifi?
Cheers
Andy
2018-5-1
Far_North
Flight distance : 278379 ft
Have you updated the firmware on your CS ?   You should get that option once up to date.
2018-5-1
AndyThilo
Yes first thing i did, assuming I just do it via ‘update’ under settings?
Is there somewhere else to update it?
2018-5-1
Far_North
AndyThilo Posted at 2018-5-1 07:19
Sorry my mistake.  I checked again and I don't have offline maps on my CS.  Guess the current version does not support it.  I got mixed up with the current Go 4 version for android phones which does support it.  CS updates always seem to lag behind on firmware updates.
2018-5-1
fansfac3dfa1
Flight distance : 183967 ft
I notice the same thing as I just got mine also. This is disappointing.
2018-5-2
DJI Diana
Flight distance : 2408 ft
Hi, the Offline Map feature is not available at present. You are recommended to cache the maps on your device:
Connect your device to the Internet, open DJI GO4, go to the flying location on the map, zoom into the desired zoom level, scroll around on the map to load the map images in all areas where you want to fly.
Hope this can help, thanks!
2018-5-5
