Genghis9
So let me be sure I understand the issue here...you went out and flew your drone with the battery, that you bought on eBay, and then left the battery in the drone after the flight until the next day, is that correct?
Two things, and I assume this is a batt for the P3 from the way it sounds...
1) How long was the flight for that battery or how long did you run the battery in the drone (motors running or not)?
2) You do know that these batteries build up and create a lot of heat when in use and it can take quite a while for them to cool down after use depending on the ambient temp etc.
Lastly, the manual says to not leave or store your battery in the drone, partly for this reason.
It sounds like you left the battery in there too long and the heat build up caused the problem, and regardless of how it worked or didn't work before. All it takes is for the outside air to be a little warmer in the storage place you left the drone & batt and the battery being a little hotter, add in no airflow around the batt or drone due to it being inside and there you have it, you baked your battery.
If this is the case, then I'm not sure how DJI will deal with this one...
Good Luck
