ND filters screw or slide
435 3 2018-5-2
Datadogie
Flight distance : 27028 ft
I bought the cheaper slide on filters and see so many buying the threaded ones. Now as has been said so many times there is no glass on the threaded barrel you take off. Are there any benifits to one or the other?
2018-5-2
Breezer74
Flight distance : 20072 ft
I'm not 100% but as far as I know you can only fit slide on with the pro - I don't own one so happy to be corrected.
With the air they are best with screw on.  You remove the ring that is fitted (no glass) and screw in the filter.  This keeps the size and weight low for improved gimbal performance. If you slide a filter over the existing ring you are adding weight and bulk which can both cause issues with the gimbal.
2018-5-2
Datadogie
Breezer74 Posted at 2018-5-2 05:56
As I said "I bought the cheap slide on for my Air" I have only tried them once and they seem to do the job for my old eyes. Hopefully, the gimble will not be affected.
2018-5-2
Breezer74
Datadogie Posted at 2018-5-2 09:51
Actually you didn't state anywhere in the title or text which Mavic you have.
"I bought the cheaper slide on filters and see so many buying the threaded ones. Now as has been said so many times there is no glass on the threaded barrel you take off. Are there any benifits to one or the other?"
This was the reason I answered the way I did, trying to be helpful.  The slide on filters you have will indeed work, as you have proven, but as they add extra weight they will put more stress on the gimbal motors.  The extra bulk may or may not cause issues with fouling on extremes of movement, especially upwards.  The benefit though is probably being able to change filters more quickly.  The screw on filters are better in every other way, quality of construction being equal.
2018-5-2
