Richie345
Cayman Islands
I've had my MA for about two weeks now and have been experiencing the same range problems. It has now been two days since I have fixed the issue.
From my understanding, the MA firmware cannot communicate with the GPS on an iPhone and the MA is not able to register what country you're in, to determine whether to use FCC or CE mode, so it automatically puts the MA in a safe mode, which limits the distance you can go. To fix this issue, you need to use an android device. Download the DJI app, ensure your GPS and location services are on and connect to your RC and MA. Depending on the country you are in you will get a notification relating to FCC or CE mode. If you are in the USA, your MA will be in FCC mode, if not, more than likely CE mode. By this point, your MA's max distance should increase dramatically.
Now, if your MA automatically goes to CE mode based on your location and you would like to have it in FCC mode, you will need to download a fake GPS app which makes your Android device's GPS believe you are in a different jurisdiction. Once downloaded, choose any location in the USA and proceed to connect your Android device to your RC and MA, your MA should be in FCC mode.
I hope this helps people out there. Once you accomplish this, the MA is a fantastic drone. Do not jump the gun and return your MA just yet.
