phantom 3 std firmware abnormal and imu abnormal after update
5162 37 2018-5-3
fansf15e3c62
Flight distance : 3802 ft
I updated to the latest firmware on a phantom 3 standard and now my drone is inoperable. I thried calibarating the imu and stops at 2%. also, thried to downgrade with no success, do I also need to downgrade the remote controler or does anybody know a solution. Thanks
abnormal firmware
abnormal firmware
2018-5-3
Rene Jensen
Denmark
Try to calibrate imu again and let it be because it can take a while be sure to put it on an even place and dont touch anything when it calibrates hope it work out for you
2018-5-3
KedDK
Flight distance : 1133038 ft
Denmark
What are the details in the overall status (tap the arrow)?
2018-5-3
P3KoYoT
Flight distance : 1846667 ft
Poland
How long did you wait during the IMU calibration? it should take up to 10 minutes and during that time do not touch the A/C - leave it in peace.
2018-5-4
fansf15e3c62
Rene Jensen Posted at 2018-5-3 22:38
i have tried many  times but it always stops at 2 % and gives me an error message about unknown malfunction. before the software upgrade i was able to calibrate the imu with no problem. I am going to buy a cable in order to upgrade the remote and see if that helps
2018-5-4
fansf15e3c62
KedDK Posted at 2018-5-3 23:10
in the overall status i get abnormal firmware and that i need to calibrate the IMU but it always stops at 2 % anc cannot pass from there
2018-5-4
WD9EON
Flight distance : 686886 ft
fansf15e3c62 Posted at 2018-5-4 08:00
The mini usb port on the Remote is only for charging.
2018-5-4
P3KoYoT
Poland
Which version of Firmware you have tried?
Did you make downgrade to earlier versions?
If you need I can share for you firmware files as below:
  • P3C_FW_V01.05.0070.bin
  • P3C_FW_V01.06.0080.bin
  • P3C_FW_V01.07.0090.bin
  • P3C_FW_V01.07.0094.bin
  • P3C_FW_V01.08.0100.bin
  • P3C_FW_V01.08.0200.bin
  • P3C_FW_V01.09.0200.bin
The underscored was very stable for me.
Let  me know if you need it.
2018-5-4
Peterx
Flight distance : 1499708 ft
Do you had a look on to the log file from the upgrade process from the SD card ?  And what FW version is it?
2018-5-4
fansf15e3c62
P3KoYoT Posted at 2018-5-4 11:12
I have version 1.9.20 . do you have a website to download that other version?
2018-5-4
fansf15e3c62
WD9EON Posted at 2018-5-4 09:32
ok thanks I thought you could upgrade the rc from there as i was watching some youtube videos
2018-5-4
fansf15e3c62
P3KoYoT Posted at 2018-5-4 00:17
i tried over 10 min but it is stuck at 2%
2018-5-4
fansf15e3c62
2018-5-4
fansf15e3c62
2018-5-4
fansf15e3c62
2018-5-4
KedDK
Denmark
fansf15e3c62 Posted at 2018-5-4 08:05
Not sure if you just repeat the Aircraft status as shown in the pic of #1 or if that is what it actually say in the Overall status.
You do see that you can tap the line for "Overall Status", notice the ">" and have some more details?
Edit: ohh you did it thanks
2018-5-4
KedDK
Denmark
It look like you have the latest firmware in place, not sure if something in the IMu has been stuck, have you had a crash?
If possible initiate a factory reset of the aircraft.
Remove the battery and while supporting the gimbal give it a gentle shake and notice if any sounds of loose things are present. Hold it upside down and give it gentle knock.
Make sure aircraft is cold, not frozen but cold, then try repeating the IMU calibration making sure AC is placed on a level solid surface and make sure no movement or shaking is present.
2018-5-4
P3KoYoT
Poland
fansf15e3c62 Posted at 2018-5-4 20:39
I put all these versions of Firmware on my Dropbox cloud ->HERE<-.
I will leave the link active to the end of weekend. I found that the best way to perform update on P3Std is ->THIS<- described by DJI, after update/downgreade on SDCard you will find text file with process summary.
I hope the downgrade will helps you, let us know.
2018-5-4
fansf15e3c62
========== 2014.01.01 00:45:07 remo-con disconnect======
Packet: P3C_FW_V01.00.0020.bin
Upgrading ...
Result: Success.
========== 2016.04.03 16:17:36 =====================
Packet: P3C_FW_V99.99.9999.bin
Upgrading ...
Result: Success.
========== 2016.12.16 15:02:46 =====================
Upgrading ...
Result: Success.
========== 2016.12.16 15:27:22 =====================
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2017.02.21 11:52:26 =====================
Upgrading ...
========== 2018.03.21 19:10:23 =====================
Upgrading ...
========== 2018.03.23 23:59:39 =====================
Packet: P3C_FW_V01.09.0200.bin
Result: Abort.
========== 2014.01.01 00:00:14 remo-con disconnect======
Result: Abort.
Result: Abort.
========== 2018.03.24 22:42:40 =====================
Result: Abort.
========== 2018.03.24 22:57:25 =====================
Packet: P3C_FW_V01.08.0100.bin
Upgrading ...
Result: Success.
Result: Abort.
========== 2018.03.24 23:22:59 =====================
Skipped: P3C_FW_V01.08.0100.bin
Upgrading ...
Result: Success.
========== 2018.03.24 23:31:45 =====================
Packet: P3C_FW_V01.06.0080.bin
Upgrading ...
Result: Success.
========== 2018.03.27 12:37:38 =====================
Result: Abort.
========== 2018.03.27 12:48:02 =====================
Skipped: P3C_FW_V01.06.0080.bin
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Result: Abort.
Upgrading ...
Result: Success.
========== 2018.03.27 21:17:17 =====================
Packet: P3C_FW_V01.07.0090.bin
Upgrading ...
Result: Success.
========== 2018.03.27 21:48:08 =====================
Result: Abort.
========== 2018.03.27 21:51:17 =====================
Result: Abort.
Packet: P3C_FW_V01.03.0050.bin
Upgrading ...
Result: Success.
Result: Abort.
========== 2018.04.24 22:13:34 =====================
Skipped: P3C_FW_V01.03.0050.bin
Upgrading ...
========== 2014.01.01 00:00:12 remo-con disconnect======
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2018.04.24 22:19:06 =====================
Upgrading ...
Result: Success.
2018-5-5
fansf15e3c62
[00018270]Waiting for user confirm...
[00028336]Timeout, start upgrade automatically.
[00028462]Firmware upgrading[1]...
[00028660][01 01] Firmware upgrade start...
[00059000][01 01] Firmware upgrade finished successfully.
[00060302][07 00] Firmware upgrade start...
[00125792][07 00] Firmware upgrade finish without reboot.
[00165844][07 00] Firmware upgrade finished successfully.
[00165909]Done.
[00165971]Version checking[2]...
[00166036][04 00][00] v1.51.0.0 -> v1.41.0.0
[00166181][11 00][00] v1.8.0.0 -> v1.8.0.0
[00166338][01 00][00] v1.14.4920 -> v1.13.4312 need upgrade
[00166403][01 01][05] v1.13.4312 -> v1.13.4312
[00166522][03 05][00] v34.2.0.9 -> v34.2.0.9
[00166643][03 06][00] v2.4.15.5 -> v2.4.10.7
[00166742][07 00][05] v1.0.9.14 -> v1.0.9.14
[00166823][09 00][00] v0.1.1.0 -> v0.1.1.0
[00166932][12 00][00] v5.9.0.0 -> v5.9.0.0
[00167029][12 01][00] v5.9.0.0 -> v5.9.0.0
[00167158][12 02][00] v5.9.0.0 -> v5.9.0.0
[00167266][12 03][00] v5.9.0.0 -> v5.9.0.0
[00167319]Done.
[00167381]Firmware upgrading[2]...
[00184265][01 00] Firmware upgrade start...
[00013843][01 00] Firmware upgrade finished successfully.
[00013905]Done.
[00013969]Packet [C:\P3C_FW_V01.03.0050.bin] resumed, card sn [0x29a225cb].
[00014041]Packet vlink 01.03.0050 <-> 01.02.0040.
[00014104]Record vlink 01.09.0200 <-> 00.00.0000 (flow = 1).
[00014174]Version checking[2]...
[00014299][04 00][00] v1.51.0.0 -> v1.41.0.0
[00014440][11 00][00] v1.8.0.0 -> v1.8.0.0
[00014508][01 00][05] v1.13.4312 -> v1.13.4312
[00014570][01 01][05] v1.13.4312 -> v1.13.4312
[00014687][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014783][03 06][00] v2.4.15.5 -> v2.4.10.7
[00014940][07 00][05] v1.0.9.14 -> v1.0.9.14
[00015032][09 00][00] v0.1.1.0 -> v0.1.1.0
[00015161][12 00][00] v5.9.0.0 -> v5.9.0.0
[00015268][12 01][00] v5.9.0.0 -> v5.9.0.0
[00015394][12 02][00] v5.9.0.0 -> v5.9.0.0
[00015534][12 03][00] v5.9.0.0 -> v5.9.0.0
[00015597]Packet upgrade finish successfully.
[00014467]========== remo-con disconnect. boot(15) ============
[00014542]Packet [C:\P3C_FW_V01.03.0050.bin] detected, card sn [0x29a225cb].
[00014603]Packet upgrade start...
[00014682]Packet checking...
[00014739]Packet vlink 01.03.0050 <-> 01.02.0040.
[00014796]Record vlink 01.09.0200 <-> 00.00.0000 (flow = 1).
[00014867]Done.
[00014933]Version checking[1]...
[00015013][04 00][00] v1.51.0.0 -> v1.41.0.0
[00015157][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015219][01 00][00] v1.13.4312 -> v1.13.4312
[00015284][01 01][00] v1.13.4312 -> v1.13.4312
[00015492][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015590][03 06][00] v2.4.15.5 -> v2.4.10.7
[00015723][07 00][00] v1.0.9.14 -> v1.0.9.14
[00015822][09 00][00] v0.1.1.0 -> v0.1.1.0
[00015957][12 00][00] v5.9.0.0 -> v5.9.0.0
[00016083][12 01][00] v5.9.0.0 -> v5.9.0.0
[00016192][12 02][00] v5.9.0.0 -> v5.9.0.0
[00016321][12 03][00] v5.9.0.0 -> v5.9.0.0
[00016383]Packet upgrade cancelled at version checking.
[00414958]========== 2018.04.24 22:13:35. boot(15) ============
[00415440]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0x29a225cb].
[00415511]Packet upgrade start...
[00415581]Packet checking...
[00415654]Packet vlink 01.09.0200 <-> 00.00.0000.
[00415835]Record vlink 01.09.0200 <-> 00.00.0000 (flow = 0).
[00416213]Done.
[00416283]Version checking[1]...
[00416354][01 00][00] v1.13.4312 -> v1.14.4920 need upgrade
[00416424][01 01][00] v1.13.4312 -> v1.14.4920 need upgrade
[00416575][03 06][00] v2.4.15.5 -> v2.4.20.50 need upgrade.
[00416895][09 00][00] v0.1.1.0 -> v0.1.1.1 need upgrade.
[00417250]Done.
[00419415]Waiting for user confirm...
[00429661]Timeout, start upgrade automatically.
[00429915]Firmware upgrading[1]...
[00498758][01 00] Firmware upgrade start...
[00012808]========== remo-con disconnect. boot(1) ============
[00012869]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0x29a225cb].
[00012944]Packet upgrade start...
[00013005]Packet checking...
[00013067]Packet vlink 01.09.0200 <-> 00.00.0000.
[00013188]Record vlink 01.09.0200 <-> 00.00.0000 (flow = 0).
[00013257]Done.
[00013322]Version checking[1]...
[00013388][01 00][00] v1.14.4920 -> v1.14.4920
[00013458][01 01][00] v1.13.4312 -> v1.14.4920 need upgrade
[00013620][03 06][00] v2.4.15.5 -> v2.4.20.50 need upgrade.
[00013712][09 00][00] v0.1.1.0 -> v0.1.1.1 need upgrade.
[00013779]Done.
[00015837]Waiting for user confirm...
[00025901]Timeout, start upgrade automatically.
[00026045]Firmware upgrading[1]...
[00026277][01 01] Firmware upgrade start...
[00040361]Packet upgrade failed at resume checking.
[00056734][01 01] Firmware upgrade finished successfully.
[00056791]Done.
[00056479]========== 2018.04.24 22:19:07. boot(15) ============
[00056547]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0x29a225cb].
[00056621]Packet upgrade start...
[00056692]Packet checking...
[00056770]Packet vlink 01.09.0200 <-> 00.00.0000.
[00056836]Record vlink 01.09.0200 <-> 00.00.0000 (flow = 0).
[00056908]Done.
[00056986]Version checking[1]...
[00057106][03 06][00] v2.4.15.5 -> v2.4.20.50 need upgrade.
[00057230][09 00][00] v0.1.1.0 -> v0.1.1.1 need upgrade.
[00057297]Done.
[00059369]Waiting for user confirm...
[00069443]Timeout, start upgrade automatically.
[00069584]Firmware upgrading[1]...
[00069976][03 06] Firmware upgrade start...
[00106135][03 06] Firmware upgrade finish failed (step = 3, err = 0xaa).
[00136219][09 00] Firmware upgrade start...
[00179352][09 00] Firmware upgrade finish without reboot.
[00209424][09 00] Firmware upgrade finished successfully.
[00209488]Done.
[00209560]Version checking[2]...
[00209646][03 06][00] v0.0.0.0 -> v2.4.20.50 need upgrade.
[00209732][09 00][05] v0.1.1.1 -> v0.1.1.1
[00209792]Done.
[00209855]Firmware upgrading[2]...
[00210214][03 06] Firmware upgrade start...
[00605955][03 06] Firmware upgrade finished successfully.
[00606021]Done.
[00606085]Version checking[3]...
[00606201][03 06][05] v2.4.20.50 -> v2.4.20.50
[00606297][09 00][05] v0.1.1.1 -> v0.1.1.1
[00606363]Packet upgrade finish successfully.
2018-5-5
P3KoYoT
Poland
Did you format your SDCard before each try? there is a hell of information with bunch of different dates and results, hard to read it or worst to understand.
2018-5-5
fansf15e3c62
P3KoYoT Posted at 2018-5-4 22:30
I put all these versions of Firmware on my Dropbox cloud ->HERETHIS
thanks. I will try to downgrade with the files you sent me. will keep you updated of the changes
2018-5-6
fansf15e3c62
P3KoYoT Posted at 2018-5-5 11:39
I formatted the card a few times. not sure why kept old dates or if that info is stored in the drone
2018-5-6
P3KoYoT
Poland
fansf15e3c62 Posted at 2018-5-6 18:28
Probably you are correct and all that info is kept in the drone.
The HYPERLINK for download is no longer available, I hope you already download that you are interested in.
2018-5-6
DJI Susan
Hi there, has the drone been involved in the crash or hard landing before? If still no luck, please kindly start a case and send the unit in for diagnosis: https://www.dji.com/support
2018-5-6
fansf15e3c62
DJI Susan Posted at 2018-5-6 20:08
no crash all I did was update the firmware and now my drone is inoperable
2018-5-7
DJI Susan
fansf15e3c62 Posted at 2018-5-7 07:31
Sorry about this. Please kindly refer my previous suggestion and send the unit in. The local team will take care once the unit arrived.
2018-5-11
user491e481821
Flight distance : 4865 ft
WHICH FIRMWARE IS BETTER  FOR THE RANGE?
2018-5-20
user491e481821
2018-5-20
user491e481821
KedDK Posted at 2018-5-4 21:14
CAN U TELL ME WHICH FIRMWARE IS BETTER FOR THE RANGE_? PLS
2018-5-20
Knobbynomates
Flight distance : 18504 ft
user491e481821 Posted at 2018-5-20 02:06
P3C_FW_V01.09.0200.bin for me
2018-5-20
user491e481821
user491e481821 Posted at 2018-5-20 02:04
i did'nt try enything. Nop no downgrade. Please share with me
2018-5-20
P3KoYoT
Poland
user491e481821 Posted at 2018-5-20 02:03
For me the range do not depend on firmware version.
Now I'm flying with latest firmware  which you can download here ->P3C_FW_V01.09.0200.bin <- from DJI webpage.
2018-5-21
Peterx
Can it be your upgrade operation was disturbed ? Did you charged batteries of all three components of the P3S system RC,AC and mobile?
2018-5-21
user491e481821
user491e481821 Posted at 2018-5-20 10:52
me too........
2018-5-21
fans5fc2f1ce
Flight distance : 228776 ft
ok this might help you i had the exact same issues and found that when my drone was confiscated they took it apart removed the sd card inside the drone and didnt put it back in when they reassembled drone...i took drone apart noticed the missing sd card and i replaced it and whala!!!! drone works perfect all errors gone your sd card probobly came loose i didnt even knoe it had one..
2018-8-22
Peterx
What FW file is on the camera´s SD card? May be it´s older than the current flashed file to the copter internal SD Card. If the FW-upgrade successful and you don´t need to upgrade any component of the P3S system then delete the FW file from the camera´s SD card.
2018-8-24
rubyduby
the reason dji ask you about a crash is all the errors your getting can be caused by the internal memory card coming loose most people like myself are unaware of this memory card hidden inside the underbelly of your drone where battery compartment is.it can become loose its only held in place with hot glue,mine recently was removed when my drone was confiscated by faa ..when i got my drone back i tried starting drone up and i got all kind of errors just like the ones your getting once i put card back in all errors disappeared drone works perfect..so it just may be that your memory card came loose ...i had also thought it was because of a recent update but was wrong...check and see if ur cards in place.
2018-8-25
