DJI GO 4 Version 4.2.14
12
6476 51 2018-5-3
djiuser_RojfSW97etD9
Flight distance : 24259 ft
DMX_MLT Posted at 2018-5-5 04:14
If you are an Outback Guy from Australia you maybe like this Song.
Its called - It Ain't My Fault (Its only my Fault (DMX_MLT) For not having v4.2.14, you still don't get it that it is UNAVAILABLE in Europe, and I just tried to give you a hand and help)
Cunny Funt
2018-5-5
DMX_MLT
Malta
djiuser_RojfSW97etD9 Posted at 2018-5-5 04:16
Help? If I told you to walk off a cliff would you? Stop guessing solutions - that's no help. But If I tell you the way it is, & you beg to differ from your own experience - it's called a debate. Please stop being emotional & respect the comments.
I am Happy I see you Smiling, for Once ! Have a Great Day Sir.
2018-5-5
https://www.dropbox.com/s/gxzzvt ... .14%5B1%5D.apk?dl=0
2018-5-5
DMX_MLT
Malta
djiuser_RojfSW97etD9 Posted at 2018-5-5 05:11
https://www.dropbox.com/s/gxzzvtg466ypkql/DJI_GO_4_4.2.14%5B1%5D.apk?dl=0
Thank you for the *.apk.
2018-5-5
nixuspix
Flight distance : 2864974 ft
Latvia
Just checked on LG G4 with Spark - OTG is supported correctly. ( Tested inside only, without the flight yet)
2018-5-5
DMX_MLT Posted at 2018-5-5 09:16
You are welcome. I hope it worked? It's a backup apk via ES File Explorer.
2018-5-5
Terp1234
Flight distance : 50906 ft
Google Play has updated my S8 to 4.2.14(583) last night. So the update has arrivred Europe as well. Although the fix for sub-zero temperatures are not really needed right now...
2018-5-5
ernieken
Flight distance : 547641 ft
Belgium
4.2.12 fixed the very bad wifi performance for me (before that version max 100m without signal loss). That was the reason for me to use OTG cable with an older version of the app.
I was happy with 4.4.12 but 4.4.14 is as worse as before concerning wifi performance. So what has DJI added to version 4.2.12 and removed again from 4.2.14? Anyone has the same behaviour?
2018-5-6
ernieken Posted at 2018-5-6 11:35
It has been too windy to test 4.2.14 here. I've had video signal problems since 4.2.8. Once 100% signal, 500m straight up (4.2.6). Now with later versions,  it disconnects at 200m, 50m, 10m at random via the RC, with the antenna in the correct direction.
Happy flying.
2018-5-9
Sparky_17
Flight distance : 62349 ft
Aurelian (Spark) Posted at 2018-5-3 23:40
And this is a screenshot from iOS update.
[view_image]
sure is .. lol
2018-5-9
Firehawk989
Flight distance : 198904 ft
Another interesting thing I've noticed with .14 is that even with obstacle avoidance off, you now get an obstacle avoidance display and warning onscreen and audio beep warnings if you get too close to anything.
2018-5-9
Grizzle
Flight distance : 39469 ft
Many thanks to you, comrade!
2018-7-30
12
