DJI Battery Station
718 7 2018-5-4
YOYOMAN
Flight distance : 676260 ft
Réunion
Hi,
Does the DJI Battery Station balance batteries when charging?
Thanks
2018-5-4
bobo
Flight distance : 1544416 ft
That's done with the battery itself.
2018-5-4
YOYOMAN
Réunion
bobo Posted at 2018-5-4 01:36
sometimes ^^
2018-5-4
DJI Elektra
Or you can drain your battery first and then fully charge and see if it can balance.
2018-5-6
YOYOMAN
Réunion
DJI Elektra Posted at 2018-5-6 19:34
hi,
What do you mean by 'drain your battery' ?
I undestand that is the process to 'balance' DJI battery, but how much % level of battery do I need to reach before stop draining?
2018-5-6
DJI Elektra
YOYOMAN Posted at 2018-5-6 23:06
hi,
Usually, when it is in 3 - 5%, it will have low power warning and it will turn itself off automatically. Then you can charge the battery again.
2018-5-7
YOYOMAN
Réunion
DJI Elektra Posted at 2018-5-7 03:24
and then, do we have to wait 72h until the balancing is finished?
2018-5-7
DJI Elektra
YOYOMAN Posted at 2018-5-7 03:27
If the app has battery error message, you can use this method. I would recommend you record the value of the battery voltage first. Then you can wait for 72h and see if the difference between the value is over 110mV. If not, you can provide a screenshot and contact us, thanks.
2018-5-8
