D.Raphael
Flight distance : 18275925 ft
marktottymy Posted at 2018-5-17 06:48
Did you turn off Color waveform ? I would try disabling waveform, histogram, exposure warning etc. anything that puts demand on the system. Also check if showing or minimizing the FPV camera feed has any effect...
Yes, turned waveform off and it works perfectly . thanks god and thanks dear Mark.
But now i have a biggest problem , with the CDNG files on Premier cc 2018, all files from the SSD become purple , since the last FW update . old DNG files that was taken before the last FW update , can be opened normally . did you met or know that mess? Are you using Premiere ?
I must find a solution, can't edit any sequence , have a lot work to do.
Thanks in advance Mark. |
