DJI Battery Station/Assistant2
589 1 2018-5-4
bobo
Flight distance : 1544416 ft
I tried connecting the mini usb plug via computer with the Assistant2. I cannot get the Assistant2 to reconize the Battery Station. I tried Assistant2 v 1.2.3 and also Assistant2 for Matrice v2. It will not connect. Also tried other cords. I connect to my Inspire2 and Matrice600 with the assistant2 and computer ok. Anyone try connecting to Assistant2 yet?
2018-5-4
bobo
Just found out from DJI Tech that there is no Assistant2 software as yet compatible with the Battery Station. So you cannot connect thru your PC/MAC via assistant2. I just wanted to post this so no one thinks there is something wrong with the Mini USB port. I was aware that the firmware for being able to update the batteries has not come out yet. Just thought that you still should be able to connect the Charger via assistant2 but no can do.
2018-5-4
