ipad 9.7 mount
1463 12 2018-5-5
bernardren07
Flight distance : 48504 ft
Singapore
Hi. I bought ipad 9.7 for my mavic pro. I will like to know which mount you used and must be stable without break or filmsy? Only i know is LIFTHOR V3 but too cost...
2018-5-5
ChaosKnign
Flight distance : 402877 ft
I’ve used a few, but they all seem to be pretty cheap. I ended up using PolarPro’s mount, even though it’s a bit pricey.
No complaints so far.
2018-5-5
rparge
Flight distance : 173852 ft
I like this one, you can spin the mount so the iPad is a bit higher or lower, and the unit balances nicely. It does block the controller Mavic screen, if you even use it with an iPad.
Skyreet Mount
This turned out to be a good cable, not too long.
Cable
2018-5-5
M2Wair
Flight distance : 1192231 ft
Here you go
http://www.mavmount.com/index.ph ... let-adapter-system/
2018-5-5
bernardren07
Singapore
Wow. much interest to hear. need to view more.
2018-5-5
B1houdini
Flight distance : 927927 ft
I have a friend who tried a few different mounts and he said most of them would work for awhile and then they would  become flimsy. He decided to make one himself out of 1/8 Plexigla. It doesn't hide the controller and he says it is a lot easier to control the drone.
I told him to send me a photo and I will post it as soon as I get it.
2018-5-5
bernardren07
Singapore
B1houdini Posted at 2018-5-5 12:09
ok. send me picture. want to see it. Thank you alot
2018-5-5
B1houdini
bernardren07 Posted at 2018-5-5 12:34
He is working on sending them right now.
2018-5-5
Ratnow
Flight distance : 840669 ft
I purchased two different mounts for the smaller ipad and decided to make my own. I took a piece of plexiglass I had in my shop and cut it to size. As you will see from the pictures I made a holder at the top that goes where you would put a phone. Then I put one of those gel pads on the plexiglass to hold the ipad. I really like it because I can s my controller as well as the ipad screen. VERY inexpensive. Probably total of 8 USD. Houdini suggested I send you some pictures so I'll try. Hope it works.
2018-5-5
B1houdini
Ratnow Posted at 2018-5-5 12:49
I purchased two different mounts for the smaller ipad and decided to make my own. I took a piece of plexiglass I had in my shop and cut it to size. As you will see from the pictures I made a holder at the top that goes where you would put a phone. Then I put one of those gel pads on the plexiglass to hold the ipad. I really like it because I can s my controller as well as the ipad screen. VERY inexpensive. Probably total of 8 USD. Houdini suggested I send you some pictures so I'll try. Hope it works.[view_image][view_image][view_image][view_image]
Ratnow
Thank you for sending them.
2018-5-5
bernardren07
Singapore
wow. how you carry this?
2018-5-5
Ratnow
bernardren07 Posted at 2018-5-5 13:01
It isn't heavy at all. A strap could be attached if you need it. I find I don't need a strap. Yours obviously will be bigger and heavier because you have the larger ipad.  I have a bag that I take with me that holds it the ipad drone (in a case) and other accessories.
2018-5-5
DJI Diana
Flight distance : 2408 ft
Hi, the PGYTECH Mavic/Spark Tablet Holder from DJI official online store: https://store.dji.com/product/pgytech-mavic-pro-tablet-holder, thanks!
2018-5-6
