Mavic Air - GPS encounters data exception
1883 11 2018-5-5
MatzeKS
Hi Guys, yesterday I got my new Mavic Air.
After upgrading the Remote Control and Mavic to latest Firmware release the DJI GO 4 (also latest release) is showing this error message:
"GPS encounters data exception, please ask technicak assistance for help" - therefore the mavic is unable to start.
Does anyone elso had the same experience and may an solution?
Many thanks for your help and effort.
MatzeKS
2018-5-5
Wachtberger
Flight distance : 261509 ft
I have not yet had such an incident and would recommend you to open a support case with DJI: https://www.dji.com/de/support
2018-5-5
MatzeKS
Wachtberger Posted at 2018-5-5 13:58
I already did this this morning, unfortunately the support team is unavailable over weekend and I try to get the Mavic up and flying asap without waiting.  ;)
2018-5-5
Wachtberger
MatzeKS Posted at 2018-5-5 14:05
I would be as impatient as you, especially since weather is so nice for flying. But better stay on the safe side I would suggest. Have you installed DJI Assistant already on your PC? If not, do it and refresh the firmware, this is the only thing that comes to my mind which might fix the issue.
2018-5-5
QuadKid
Flight distance : 482349 ft
I would try to refresh the firmware using Assistant 2 , then find a clear unobstructed area where you are sure there is no interference and see how many satellites you can lock on to, if you can lock 12 or better you should not be getting that message, if you get the same error message there is probably a receiver issue in the drone itself.
2018-5-5
MatzeKS
Wachtberger Posted at 2018-5-5 14:11
all done, latest DJI Assistant installed and connected with my Mavic. Latest Firmware is loaded and activated. At least I reset the Mavic to factory defaults via DJI Assistant and additionally by pressing the function button on the mavic (3 beeps).
Same issue after all of those procedures.
2018-5-5
MatzeKS
QuadKid Posted at 2018-5-5 14:14
Ok, I'll try this after my sleep - now I've go to bed finally (00:17AM)  ;)
I'll keep you updated guys - thanks so far.
Good night
2018-5-5
Wachtberger
MatzeKS Posted at 2018-5-5 14:15
Follow the procedure QuadKid has suggested here above, it might solve the issue. And good night from my side as well, we are in the same time zone, even the same country ;-)
2018-5-5
DJI Diana
Flight distance : 2408 ft
MatzeKS Posted at 2018-5-5 14:18
Hi, I'm sorry to hear about the issue that you are experiencing. As the floor 5# mentioned, please try the procedure and do the troubleshooting. If there is any further issue, please feel free to let us know, we'll here for help. Thanks!
2018-5-6
MatzeKS
DJI Diana Posted at 2018-5-6 20:16
Good morning, there is no issue reaching the right amount of GPS satellites, there is an issue (exception) to address the GPS modul/device inside of my Mavic.
So, therefore the Mavic is unable to reach any  GPS satellite due to non-functional GPS module inside.
Let's see what the DJI support team can do. hopefully they'll contact me asap  ;)
Thanks so far - MatzeKS
2018-5-6
DJI Diana
MatzeKS Posted at 2018-5-6 22:01
Hi MatzeKS, sorry for the inconvenience. You are recommended to contact our support to start a case and send it in for diagnosis: https://www.dji.com/support. If there is anything else we can assist you with, please feel free to let us know, we'll here for help.
2018-5-7
MatzeKS
DJI Diana Posted at 2018-5-7 23:39
Hi Diana, yesterday I opened an support case with DJI.
My package received the DJI Repair Dept. 2 minutes ago
The bad thing is, that I have to pay the insured shipment by my own, although I am not responsible for the damage at all.
2018-5-7
