Error Code 200 - Mavic Air
31965 36 2018-5-6
James Mavic Air
Flight distance : 1916 ft
Hi Guys,
After 3 successful flights, I thought I would try the Hand gesture mode. Was all set up to fly but would not take off. All I know recieve is "Cannot Fly" Error Code 200
Saw that someone had done a factory reset to cure this? but I'll be damned if I can find a way to do it?
Can anyone help?
Cheers
James
2018-5-6
Wachtberger
Flight distance : 261509 ft
Download DJI Assistant, with that you can factory reset and also refresh the firmware: https://www.dji.com/mavic-air/info#downloads
2018-5-6
James Mavic Air
Wachtberger Posted at 2018-5-6 07:22
Many thanks Wachtberger, I've downloaded the DJI Assistant 2 and installed it on my laptop. It does not seem to be working. The assistant opens and I have a screen with a USB connect graphic.
I've logged in and connected the USB to the controller and the Laptop, Nothing appears to be happening.
Windows 7 Professional which shouldn't be a problem?
Many thanks for your reply
James
2018-5-6
James Mavic Air
James Mavic Air Posted at 2018-5-6 10:09
Arrrgh Damn my old Brain... connected the Mavic Air. My bad fella. Looks to be working now.
Thanks for your time
2018-5-6
Wachtberger
James Mavic Air Posted at 2018-5-6 10:20
You are very welcome! :-)
2018-5-6
DJI Thor
Flight distance : 13602 ft
Thanks for Wachtberger's help and glad to know that the issue was resolved.
2018-5-13
djiuser_Xtl4FVwki3lG
Sweden
In my case it was faulty SD card.
Just removed it and went back to internal storage. Before that tried factory reset and update, but it didint solve a problem.
Paulius
2018-8-1
DJI Tony
djiuser_Xtl4FVwki3lG Posted at 2018-8-1 15:37
Hi, Glad to know that. Please keep us posted in any case you need our assistance.
2018-8-2
djiuser_PRlaYE8TMMXn
Turkey
Hi.. I got tge same error code 200..have restarted through assistant 2..but still same peoblem
2018-11-25
YvesEickelberg
Flight distance : 11145 ft
Switzerland
Indeed, I have the same issue : Code 200 when trying to take off !
Firmware upgrade:
- After failing to upgrade the firmware from my Window10, I succeed using my MacOS.
- I updated the Mavic 2 zoom with firmware v01.00.0000, v01.00.0100 and finally v01.00.0200.
I also proceeded to a factory reset.
I shut down and shut up again the drone before, after each operation.
I was occasionnally able to proceed to some fly, but mostly the error message Code 200 appears when trying to start the engine.
Additionnaly, I was never able to receive any image from the drone.
2018-11-25
Yadhel
Flight distance : 349800 ft
Mexico
YvesEickelberg Posted at 11-25 05:12
Firmware upgrade:
I have the same problem, is there any fix?, I tried contacting dji Support but they gave me no answer, they reply that I had to "disconnect" usb and restart the mavic... I don't even have any usb connected
2018-12-14
dholanda84
Flight distance : 636 ft
Brazil
Solved Error 200?
2018-12-28
Yadhel
Mexico
Not yet... I'm still "grounded"
2019-1-14
Marco Filipe
Flight distance : 3068045 ft
Portugal
I have the same error at this moment... turn off and on and dissapear...
2019-1-15
Luistroy
Flight distance : 385961 ft
Argentina
same error here...
2019-1-21
DJI Tony
Hi, we do apologize for the incovenience that it may cause. I would like to ask what happened to your aircraft prior to encounter this error message? You may follow the troubleshooting steps below to see if that would rectify the problem, however, if the troubleshooting steps, please contact our support for the further diagnosis of your drone. You may refer to this link: www.dji.com/support
1. Re-insert the USB cable of the Remote Controller;
2. Remove USB cable of the aircraft and SD card;
3. Restart the aircraft.
2019-1-22
djiuser_ULIMWvwnZqTh
Indonesia
YvesEickelberg Posted at 2018-11-25 05:12
Firmware upgrade:
Hi, did you find the solution for your issue?, I have same error
2019-7-8
fans7e0d9bc7
Sobu dont get error 200 message no more
2019-7-12
djiuser_8wEXLpb5q4Sb
Firmware upgrade:
no he podido resolverlo
2019-8-7
krikire
Hello,
I am now begging for help. I am currently traveling with my motorcycle for a year and a half in latin america and my Mavic Pro 2 keeps having so many problems...
And now it has exactly the same problem as you described !
"Error 200, please check the usb connection with Airraft. Contact DJI Support if this error persists after restarting"
I have no image on the screen, it's full gray. The sensors seem to be working however. But image nothing and I can't take off because of error 200.
There also is a SD card inside but the drone does not detect it. It says there is no SD card.
I am so desesperate because it takes a lot of space on my motorcycle and traveling with a drone I can't use in such amazing places is a torture. And in these poor countries nobody has a clue about drones and nobody can help me repair it sadly... What can I do guys ? Plz help !
I tried to remove the SD card, remove cable, update firmware... everything, please helf
2019-9-17
djiuser_VYAIm7CSWnTc
Just got mavic zoom,  error code 200, no video,  I have smart controller.  Flown 4 times, pictures  go grey. Done updates, 200 code won't  go away!
2019-12-9
djiuser_VYAIm7CSWnTc Posted at 12-9 12:02
Im grounded, guess I'll send back for refund. I'll  try a few more attempts.
2019-12-9
Error 200, I'm grounded,  done the updates,  flew four times all four times screen  goes grey . Dissatisfied with mavic zoom . I got the smart controller. It's got problems.
2019-12-9
spankya29
I just did the firmware update on my drone and controller  and now I get a error code 200  gimble disconnected  cannot locate internal storage  cannot fly  I did the refresh and restore to factory settings  with the assistant 2  nothing works   help
2020-1-27
O Ynot
Flight distance : 220079 ft
spankya29 Posted at 1-27 18:54
Apologies if this has already been done, but have you tried replacing the cable between your mobile device and the controller?
2020-1-28
spankya29
I replaced the cable. Used the one from my spark
2020-1-28
fansb554b6fe
I have a spark. A mavic air. A phantom 4. And a phantom 4 pro plus. I do all updates. Regularly. No fly zones everything. This is the first time I have ever had any problems.
2020-1-28
Drones.Medellin
Colombia
SOLUTION FOUND
Hope you have this same issue, I found that the GIMBAL FLEX (Metallic one) was damaged, it didn't have any physical damge, It's like I turned on the drone and it burned or something
Make sure you buy a couple and be very carefull when you install it.
Mine damaged from no where
GIMBAL FLEX LINK
2020-4-27
cfigu65761
Firmware upgrade:
did you ever fix same problem and dpi just want me to send it to them before helloing ?? please
2020-5-14
cfigu65761
DJI Tony Posted at 2019-1-22 16:42
Horrible customer service
2020-5-14
cfigu65761
wow no-one has solved th problem
2020-5-14
Faro Del Sur
Argentina
Buenas tardes a todos; desde la Patagonia Argentina, les comento que tuve que hacer un servicio a un DJI Mavic 2 Pro, con este error; y lo solucioné cambiando el cable flexible que une al drone con el gimbal.
2020-12-1
TruGreen
Flight distance : 621909 ft
error 200 has to do with the internal flex cable of the gimbal/camera. i have a M2 Zoom that i removed the gimbal from and it gets the error. put gimbal back on and error gone. then my buddy recently crashed his M2 Pro and had the same error 200 and his gimbal had blank display and didnt sit level. he took it apart and found broken wires
2020-12-1
djiuser_W1qO2Bwi75sd
Turkey
Please help ..any solution for this issue ?????
2020-12-8
Fran Untildeates
Argentina
Faro Del Sur Posted at 2020-12-1 11:51
Hola man, es la única solución? Estoy pasando por el mismo problema. Tengo el mismo dron
2021-1-13
Purplenirps
Flight distance : 352356 ft
I'm on a weeklong production and keep running into this issue. What I've discovered for me is it was a BATTERY firmware issue. So anytime I got that code, I would put that battery into my mavic 2 pro, plug it into my laptop and run the DJI assistant for mavic 2 and upgraded firmware and that seemed to solve it for me. Decided to come back and reply since I haven't found an answer on any other forums. Good luck anyone looking.
2022-5-29
DJI Gamora
Hi, there. If the DJI GO 4 app reports “error code 200”, perform the following:
1. Re-insert the USB cable of the remote controller.
2. Re-insert the USB cable of the mobile phone.
3. Re-insert the microSD card of the aircraft.
4. Restart the drone, remote controller, and the DJI GO 4 app.
If the issue persists, please send the products back for diagnosis
https://repair.dji.com/repair/index
We will do our best to help this out.
2022-5-30
