New Focus Motor will not connect
989 1 2018-5-6
HarrisonStagner
I just purchased a new DJI motor and it won't connect with my existing handwheel unit.
Evey time I try to connect the motor it reads "failed".
- Using “Link Botton method” (on controller) and “Menu method" (Settings - Connect Motor - Connect)
        - installing new controller firmware (version 1.6) multiple times using DJI Assistant software
        - power cycling controller and motor
        - restoring default settings to motor and controller.
        - All of the above dozens of times, in various orders, with and without LEMO “Communications Port” cable connecting the devices.
Thank you,
Harrison
2018-5-6
DJI Elektra
Please tell me the model of your drone. And I would recommend you check if you have the right procedure of mounting the focus motor: http://dl.djicdn.com/downloads/f ... _Manual_v1.2_en.pdf
2018-5-9
