KedDK
Flight distance : 1133038 ft
Denmark
Are you sure you get the right version imported into your editing software, there are 2 versions recorded at the same time on the SD, one version is very bad to look at on a regular monitor.
Can you see if the imported material is actually in HD/4K resolution?
Edit: make sure you import the files from /DCIM/100MEDIA/ and not the files from /MISC/THM/100/.
