DJI Thor
Flight distance : 13602 ft
Hi Max, just to verify, did the drone or gimbal shake when it hovered? If yes, I suggest checking if the propellers are damaged, change them when necessary; try to calibrate the IMU and gimbal, if possible, also calibrate the VPS system; avoid flying when there is a strong wind and much interference around.
If it doesn't help, you might need to send the drone back for an overall check. Please contact our support for a further help: http://www.dji.com/support |
