How long for update
725 5 2018-5-7
m1shootr
Flight distance : 118894 ft
Trying to update MA via DJIGO4. Seems stuck on 99% for almost an hour now. Called for disconnecting and reconnecting rc: did that. I've never had an update take so long. Am I wrong? Any ideas?
2018-5-7
3-D
Flight distance : 635764 ft
Mine hung the first time i did it.  I disconnected and then rebooted RC and MA.  It worked perfectly that time.  only took about 5 minutes
2018-5-7
saviour
Flight distance : 604203 ft
Failed for me, too when I had my MA fresh out of the box. I just reconnected, rebooted and it worked.
2018-5-7
m1shootr
saviour Posted at 2018-5-7 04:25
Yep, did the same with same results. Thanks for the replies! All is good.
2018-5-7
DJI Thor
Flight distance : 13602 ft
m1shootr Posted at 2018-5-7 04:34
Sometimes the upgrade might be stuck at 99%. If it kept a long time, users can restart the drone, and check if the firmware update successfully in the app. If all is good, no worries.
2018-5-7
MidEastBeast
Use the DJI Assistant tool and update via your computer instead of through the app.
2018-5-7
