Side shift in stationary flight
604 7 2018-5-7
Lex_Luchor
Flight distance : 98179 ft
Hello folks!
I have problems with my Spark. The drone is performing a side move in stationary flight. Also turns to the right.
What I can do for correcto this problem?
Thanks!
Regards,
2018-5-7
heliman
I would try doing the stick calibration procedure in the go app.
2018-5-7
Aurelian (Spark)
Flight distance : 903350 ft
The propellers are in good condition?
2018-5-7
S-e-ven
Flight distance : 5922034 ft
Thailand
Change the Props for a try
What ground is under the spark?
How bright is it
How high?
2018-5-7
DJI Elektra
Lex, please try to calibrate your compass and IMU. I would recommend you check if the props are damaged. Please keep us updated, thanks.
2018-5-7
Lex_Luchor
Thank you for your answers.
The propellers are new, Those have two weeks of use.
The ground semi-desert terrain, non-reflective.
I  try to calibrate your compass and IMU.
2018-5-8
S-e-ven
Thailand
Lex_Luchor Posted at 2018-5-8 00:56
Is you "semi-desert terrain" having recognisable pattern?
In case your Spark is flying low, and the ground is to homogen for the VPS, or in case it is not bright enough, your bird may think, it is pefectly astill hovering in plave, but moving. Perhaps with some wind or tha own designed airflow!
In this video you can see what I mean,
Even if it is the reverse, a moving carpet, which the spark follows to stay "positioned" over the ground
2018-5-8
DJI Elektra
Please keep us updated and you can test your drone in a place without interference. Here is the recommended flight place for your reference.
2018-5-8
