fans8d082bd4
Hi I need some help...
I did not play my drone for a while... Last time I update the drone to its latest firmware about 7 months ago... but after that I did not check and did not fly it.
Today I turn everything on, the picture on my samsung phone screen is very bad, like below...
It is like the signal being interupted badly. and my DJI go 4 requires an firmware update, but when I tried to use dji go 4 to update the firmware, it did not work, so I have to use the pc version dji assistant 2 to update the firmware... even so, the monitor screen of DJI go 4 is still messed up.
Then I found that the left led led on the RC is flashing red and green, I check the manual, it means "HD downlink disrupted"... it never happened before...
I check the internet and found somebody suggest that the remote control need a fireware update, so I tried one of them, I found my current RC firmware version is 1.8.0, in the main page of DJI go 4, I press and hold the button at the upper-right corner, but it seems that the 1.8.0 is the latest version already. since it does not work, I tried to downgrade it to 1.6.0, but the problem still existing. and now I could not upgrade the RC firmware back to 1.8...
I have been trying to turn RC and the aircraft on and off, but it does not work, some time the RC starts to beeping and show the blinking red light, the manual says it is "RC controller error..."
My drone is phantom 4,
Firmware version is V02.00.0700, I tried couple of time to update it with DJI assistant 2
My RC control firmware now is 1.6.0
Does there anybody has the same problem, and anybody know how to fix this problem?
Thanks a lot,
Li
