Mabou2
Flight distance : 811257 ft
DJI Mindy Posted at 2018-5-13 23:58
Mahou, sorry for the late response, when you charge the RC, please make sure the RC has been turned off, and then connect to the power supply via the included Micro USB cable, solid red means the RC is charging, please wait patiently until the LED indicator becomes solid green.
Just to verify, the RC has no response when you connect to the Micro USB cable right?
Hi Mindy...
"The Power Supply" is the key to my question. The manual warns me to only use the supplied cable to charge the RC, but THE MANUAL NEVER SAYS WHAT POWER SUPPLY TO USE. It won't plug into the AC charger for the Ronin batteries... so what power supply do I use?
If the answer is that I need to use any USB port, are there limitations to this? For example, can I connect it to my Anker quick charger? Is there a max/min Amps/volts?
This is a really strange omission from the instructions. Either that or I have simply lost my mind.
