Making Osmo and Lightbridge 2 work together
812 2 2018-5-7
bryan
I am trying to find a way to use Lightbridge 2 to live stream footage from the OSMO (and DSLR cameras for that matter) - ie "on the ground" filming, to HDMI devices eg TV.
I have not bought either product as yet but will do so if it can be achieved.
If someone could provide an opinion on my proposed setup I would be very appreciative.
Attached is a diagram showing the proposed setup hence the need for a workaround using an Apple Lightning to HDMI AV adaptor. https://www.gadgets4geeks.com.au/epages/shop.sf/en_AU/?ObjectPath=/Shops/gadgets4geeks/Products/S-IP6G-1204B
I guess getting LB 1 is an option and it is much cheaper but I do not believe it to be compatible with iOS - and as much as I do not like Apple, it is needed in the proposed setup.
Anyhow, if this works it would be fanatstic.
Many thanks!!
2018-5-7
bryan
Anyone able to comment on this?
2018-5-9
SamStewart1
Flight distance : 33031 ft
Hi,
I would be really keen to know if you managed this? I am working on a project that requires something like this.
I have extended the wifi from an OSMO before using a wifi extender. But I would love to have control over it with a remote controller and light bridge.
2018-5-30
