HedgeTrimmer
QuadKid Posted at 2018-5-11 00:38
CS is designed for being able to see the screen in direct sunlight, it is a metal that heats up like the hood of your car in sunlight, I have set mine down with it turned off in the sun, went to pick it up and it was very hot and got an Overheat warning instantly. Overheat has nothing to do with the being able to see the screen. Main reference is to keep it in a cool shaded palce until ready for use.
I get idea of keeping CS out of sun till you need to use it. However, the act of using CS in the sun is going to quickly have same effect.
Sure the fan inside is running while in use, but fan is there to remove some of heat generatred by electronics inside. Other heat generated by electronics inside is disipated through chassis holding electronics. Later part accelerating heating, from being used in sun.
Really comes back to poor design for intented purpose of CS.
Be glad cars don't overheat and shutdown from being parked in sunlight.
