FPV horizon issue
1758 6 2018-5-8
fansbd663903
Flight distance : 2338192 ft
My FPV camera horizon is not level. Can I calibrate? If not what can be done short of sending it back to DJI.  I’ve seen in another post that DJI support can add FPV horizon adjust capabilities to the Assistant 2 software on request. Is this accurate.
2018-5-8
Hi there, FPV gimbal of Inspire 2 can be calibrated in Gimbal Settings, please make sure all the firmware and the APP have been up to date and adjust FPV to have a try. GTScreenshot_20180508_210241.png
2018-5-8
fansbd663903
Wow.  Missed that.  App and firmware are current. Will try immediately. Thanks for the super fast response!!!!!
2018-5-8
fansbd663903
@DJI Mindy
Followed your instructions and FPV Gimbal has been adjusted and reset.  Rebooted system and settings were retained.  Thanks again for the quick professional response.
2018-5-8
fansbd663903 Posted at 2018-5-8 05:28
@DJI Mindy
You are welcome, glad to know the issue was figured out, hope you have a good time on flying.
2018-5-9
Derek Lowrey
Flight distance : 5186749 ft
DJI Mindy Posted at 5-9 23:55
What if that doesn't affect the FPV Gimbal angle? Mine is stuck at 45 degrees left. What's this adjustment via the Assistant app all about?
2018-11-29
Derek Lowrey Posted at 11-29 10:47
Hi Derek, do you mean the FPV gimbal is stuck at 45° left? If there is no response via 'Adjust FPV gimbal', please try to refresh the firmware to see if it helps.
2018-11-30
