Sky Pixel 360 VR Panorama Viewing Issue
3424 10 2018-5-8
dinokath
Flight distance : 34068 ft
Hi all,
Up until recently, I had no problem viewing the SkyPixel 360's in VR panorama mode. Now when I look at them, the sensitivity is WAY up and it isn't a '1 to1' movement ratio. When NOT in VR mode, it is perfectly smooth but once you go VR and stick it in the Google Cardboard, it gets jerky.
I am using a Samsung Galaxy S7. I have tried it on two S7's and it is the same. On a S6 though, smooth as silk. Any suggestions? I've done the 'Calibrate Gyroscope' and keep getting a calibration failed. When the phone is laying down on the table totally still the picture is very jerky
Both S7's are up tp date with the latest Verizon firmware and have both been wiped clean.
Thanks!
Dean
2018-5-8
S-e-ven
Flight distance : 5922034 ft
Thailand
-Both S7's are up tp date with the latest Verizon firmware and have both been wiped clean. -
So the S7 have Oreo
And the S6?
2018-5-8
dinokath
S-e-ven Posted at 2018-5-8 08:44
So the S7 have Oreo
No Oreo yet on the S7 'Coming Soon' it reads when I update. The S6 not sure about, it's not with me at the moment. Using Chrome browser if that helps!
2018-5-8
S-e-ven
Thailand
-Using Chrome browser if that helps!-
Helps only, if you arent using chrome on the S6
I would look for the differences to spot, between the devices.
Usually the hardware should have all the needed sensors, and you wrote that it worked before.
And that on 2 S7 hardware brook coincidentely? Not really!
So the update and the whipping may have changed something.
What does the S6 have, that the S7 now do not have?
2018-5-8
dinokath
All three phones are wiped clean and updated to the latest firmware from Verizon.
2018-5-8
Oto
Flight distance : 540348 ft
Latvia
Same issue calibration doesn't work and the view is too sensitive. VR Unusable on S7.
2020-6-5
Oto
Latvia
2020-6-5
Oto
Latvia
Found a solution to my problem, by by skypixel.
roundme.com works without issue.
2020-10-16
SHERLOCKHOLMES
India
Hey refer to Google for more effective answer
2020-10-19
Alpha_DJI
SHERLOCKHOLMES Posted at 2020-10-19 04:24
this is exactly where google brought me to
2021-7-7
Alpha_DJI
The VR goggle function no longer works on sky pixel
2021-7-7
