My Spark is now a submarine
1580 24 2018-5-8
Chutchy
Flight distance : 195692 ft
So, I'm sure you've heard this a hundred times, but my spark decided to land in a lake instead of returning to home.  It was flying great and then I just lost signal with the remote. I think I will get my scuba tanks filled and try to find it later.  Maybe the props will still be good.  But anyways. I was woundering if some one could scrutinize my flight data and tell me what I did wrong or what happened.  All software was up to date and calibrations were done.  Here are my logs  http://www.phantomhelp.com/logviewer/VW0FRP81Q7U5QESSB4HJ/#
  Thanks
2018-5-8
Blellow
Flight distance : 1311056 ft
How far out we're u?
2018-5-8
DJI Elektra
Chutchy, sorry for your lost. Please contact our support and start a case: http://www.dji.com/support You can provide the flight record to our support and locate the problem. Thanks for your support.
2018-5-8
davidmartingraf
Flight distance : 108805200 ft
Good luck with your findings.
2018-5-8
LouisP
Flight distance : 41952 ft
Nothing in that log file to indicate what the problem was.. maybe the battery eject thing happened.  If it had simply disconnected from the controller it should have initiated a return to home.  Sounds like you have a good case for getting some help from DJI
2018-5-8
marlowe
Flight distance : 300932 ft
LouisP Posted at 2018-5-8 18:48
Interesting - 11 seconds after going into Sport mode.
2018-5-8
heliman
Did it carry prop guards?
2018-5-8
ped078
Flight distance : 565794 ft
That's a sudden death / battery eject.
2018-5-8
Adam Krakowiak
Flight distance : 33812 ft
Poland
After reading lot of posts of Spark users that battery disconnects during the flight, and reading your log's... i'm pretty sure that same thing happen to you.
You were frying, and suddenly end of log's without decreasing altitude.
Can you tell, how often you removed battery from Spark? Was it couple of times, dozens or hundreds ?
2018-5-8
JJBspark
Flight distance : 12477300 ft
Hi Chuthcy,
If the setting RTH is to Hover than it stayed there till run out of juice > 10% power landing  > wet.
I have read that after SW update some of the setting will change their values.
cheers
JJB
2018-5-8
Adam Krakowiak
Poland
@JJBspark - log's ends when battery is still 44%
2018-5-8
JJBspark
Adam Krakowiak Posted at 2018-5-8 23:42
Yes, i know. But if the drone/rc is disconnected your flightrecord stops with getting data.
Drone can hover disconnected until batt runs out.
2018-5-9
Chutchy
I was about 850 feet out and 64 feet up.
2018-5-9
Chutchy
Adam Krakowiak Posted at 2018-5-8 22:57
The battery probably had less than six flights on it.
2018-5-9
Chutchy
heliman Posted at 2018-5-8 22:10
At the time of the flight, I was not using the prop guards.  I was filming a fishing tournament and wanted to keep it light as possible.
2018-5-9
Adam Krakowiak
Poland
Did you saw your Spark when it fall down to water?
If yes, was it long after you lost connection ?
2018-5-9
m1n1s
Flight distance : 319915 ft
Sorry for your lost but it looks like battery ejection , a feature of the DJI Spark
2018-5-9
Chutchy
Adam Krakowiak Posted at 2018-5-9 03:58
No, I'm not a 100% sure.  I had a spotter with me. When I told him I last connection, he looked at me, then back at the drone and it was gone.  It was a perfectly clear day, so it should have been easy to see.
2018-5-9
Chutchy
m1n1s Posted at 2018-5-9 04:27
That's what I'm afraid of.  I read a lot about that before I bought it, so I was ALWAYS very careful about checking it.  But, I guess it only takes once.
  I still haven't told my wife yet, cause I still came home with all the phantom video.  Wish me luck
2018-5-9
Gunship9
Never fly by radio control what you can't afford to crash.  Never fly over water what you can't afford to lose.  Fortunately the Spark, and other very capable drones, are getting cheaper.  Great chance to get a Mavic Air.
As the Porsche dealer asked the car owner's teen age son (and his friends):
2018-5-9
Adam Krakowiak
Poland
Chutchy Posted at 2018-5-9 06:57
Just don't tell her, and check when she will notice
2018-5-9
Sparky_17
Flight distance : 62349 ft
sorry for your loss
2018-5-9
Sparky_17
Chutchy Posted at 2018-5-9 02:03
flying that close to water can be problematic.  I never fly any lower than 100ft and even then I get extremely nervous
2018-5-9
Chutchy
Not sure if this will work, but here is the finished video that I was working on when I had my misfortune. This is with the Spark and the Phantom.
https://www.facebook.com/clay.hu ... /10156311307383180/
p.s. I did send my logs to DJI. I'm hoping they have some wizardry and can figure out what happened.
2018-5-9
Jeetley
Flight distance : 123944 ft
sad to hear..hope all goes well
2018-5-9
