Inspire 2 V1 & V2, what's the difference?
4470 27 2018-5-8
Paul Suthard
Flight distance : 116634 ft
I see on the downloads that the inspire 2 have two different versions. Is that the difference in the T650 and the T650A? What are the differences. Also, i have to Q-Code stickers. different numbers. see photos...
2018-5-8
Jbundy63
Flight distance : 9583182 ft
I only know of the Inspire 1 being a V1 or V2 version?  My Inspire 1 is a V2 and my Inspire 2 is just like yours T650A and both Q codes are different numbers as well.
2018-5-8
Paul Suthard
here is a screen shot from the downloads page I took a few minutes ago. shows 2 different versions....
2018-5-8
Jbundy63
Paul Suthard Posted at 2018-5-8 17:56
here is a screen shot from the downloads page I took a few minutes ago. shows 2 different versions....[view_image]
WOW I hadn't noticed that! That's a good question? I'm not sure?
2018-5-8
Paul Suthard
so what are the different q codes for?
2018-5-8
Jbundy63
Paul Suthard Posted at 2018-5-8 18:12
Hmm I can't figure that out either? I have 6 other DJI drones and the Inspire 2 is the only one that has 2 Q codes, my  Mavic Platinum has 2 and they say underneath App and more and the other is for your WiFi password but I really don't know on the Inspire 2. I did notice that my Inspire 1 V2 is a model #T601 and I think the V1 is a model #T600 so maybe the A on the end of the T650 ? Is the V2 version. Not sure maybe someone can clarify!
2018-5-8
Paul Suthard
Yeah, same for me on my mavic. I have 2 inspire 1's, a pro and a raw. the pro is T600 and raw is T601. my phantom only has 1 sticker.
2018-5-8
Jbundy63
Paul Suthard Posted at 2018-5-8 18:27
Yeah it has to mean something! Hopefully someone can give an answer  LOL
2018-5-8
AvatarAir
Flight distance : 150932 ft
It's version 2 of the manual.
2018-5-8
Paul Suthard
AvatarAir Posted at 2018-5-8 18:50
ok. and what is different between model T650 and T650A?, and the firmware is different.
2018-5-8
Greg Inspire 2
Flight distance : 10262 ft
South Africa
The maximum take off weight has increased from 4000grams to 4250grams.
DJI please clarify what this new manual is and how the maximum take off weight has increased
2018-5-9
ToscanaDrone
Flight distance : 13833304 ft
Maybe new payload is coming?
2018-5-9
Hi all, the difference between Inspire 2 V1.0 and V2.0 user manual in the download page is the RC mounting bracket is different. The drone is the same. No worries.
@Paul, the SN underneath the battery compartment is the SN of the aircraft body, the SN inside of battery compartment is the SN of CineCore, which is used to purchase License.The model of Inspire 2 is T650A, where did you see T650?
2018-5-9
Paul Suthard
DJI Mindy Posted at 2018-5-9 23:37
Thank you for the clarification. I thougth I had seen 650 in the specs on the website, but I guess I am mistaken.
2018-5-10
Paul Suthard
Thanks again for your help. I am hoping to purchace DJI Care refresh for the Inspire later today, so should I use the cinecore # or the frame # to make sure that if it needs to be replaced that I can retain the licenses that are with it now?
2018-5-10
Greg Inspire 2
South Africa
Why has the maximum take off weight increased from 4000g (in V1.4 manual) to 4250g (in V2 manual)
Please explain this
2018-5-11
Mad_Angler1
Flight distance : 2741657 ft
this is just updated spec to reflect the the X7, DJI have respecified the Inspire 2 to now be capable of 4250g. no hardware change just a paper spec increase based on testing with new camera
2018-5-11
Paul Suthard
Mad_Angler1 Posted at 2018-5-11 11:00
actually, it's one thing more according to Mindy from DJI
"Hi all, the difference between Inspire 2 V1.0 and V2.0 user manual in the download page is the RC mounting bracket is different. The drone is the same. No worries."
so no big deal
2018-5-11
Greg Inspire 2 Posted at 2018-5-11 10:23
Please explain this
Greg, the Max Takeoff Weight of Inspire 2 is 4250g, we will modify the user manual V1.0, sorry for the confusion.
2018-5-15
Greg Inspire 2
South Africa
DJI Mindy Posted at 2018-5-15 01:08
Thank you
2018-5-18
iFly2
Flight distance : 194370 ft
That change is actually quite annoying for a lot of countries like mine make a legal distinction between RPA's 'up to and 4 kg' and 'above 4 kg' in terms of needed certifications!
Especilly since the drone hardware actually hasn't changed.
Also a lot of stores' websites if not all, still mention the 4.00 kg as MToW for the Inspire V2.
This is a rather unpleasant surprise, to say the least!
2018-6-21
iFly2
Forgot to add that private flying now is off limits in a lot of EU countries, given the takeoff weight is above 4kg.
Only fully certified flying under a complete and certified operational manual would be legal.
This is so crazy!
2018-6-21
iFly2
No worries??
Haven't you realised at DJI that with this new MToW the drone over here in a lot of EU countries will be classified differently!
It now will only be possible to fly under full operational manual and only with fully certified pilots?
WHAT HAVE YOU DONE!
2018-6-22
iFly2
Have you also noticed that the table with specs at the end of the 28-04-2018 version manual only mentions the T650, but with the increasd MToW of 4.25 kg?
This would mean that all Inspire 2 now officially classify as MToW > 4 kg!
2018-6-22
Altitude Drones
Flight distance : 1488520 ft
I'd say that as I brought the I2 as advertised as under 4KG and that original  I2 manual is in my OM then thats the way it is. If however you purchased the I2 after the new release of the manual then you should adhere to the over 4KG classification.
You could download an original manual and use that in your OM.
Luckily in the UK the classification is between 7KG, but I hold a Spanish license that would be effected.
Pain in the butt!
2018-6-22
Masemoto
Flight distance : 5137425 ft
Was just looking at the Inspire 2 in the DJI store and saw this picture.  What is the white cable on the undercarriage in this photo? Saftey cable in case of crash and gimbal breaks off?
Also looks like it now comes with a different Crystalsky like tablet/phone mount.
2018-6-27
BIGDZ
Flight distance : 10255860 ft
Masemoto Posted at 2018-6-27 15:17
[view_image]
2018-6-27
Bitt3rsun
Flight distance : 189469 ft
[view_image]
I just received my Inspire 2 with the new Crystalsky monitor bracket and the phone/tablet adapter.
2018-6-28
