geohei
Flight distance : 663061 ft
KedDK Posted at 2018-5-10 02:22
As you are able to switch between 2.4 and 5.8 it is not htat kind of issue i first suspected, actually strange that you then can not enter the custom settings.
I would from here think it is the GO4 App that is strange and if possible try a previous version to see if it works there. Other suggestions is try to have a factory reset/FW reflash initiated on the RC or if possible try with a Android device, i believe the setting is saved on the RC so it should be keept even when connecting the iOS device back afterwards.
1. I tried the DJI GO 4 (4.2.20) now on iPad and iPhone (both iOS 11.4). No joy. Custom not selectable
2. How can I install a previous version of DJI GO 4? Is that possible with iOS?
3. I did the RC reset. Didn't help either.
Yes, the setting is indeed saved inside the RC.
I'll try the Android connection if nothing else helps.
BTW ... can you confirm that the RC reset is:
a. RC on.
b. Press C1, C2 and Video Recording Button simulatiously.
c. Wait until Power LED goes blue flashing (long beep, 3 quick short beeps, then continues long short beeps).
d. RC off, then on again.
Is that correct?
Also ... the drone /RC pairing survived the reset. Is this the way it should be?
