felixlim
Flight distance : 404285 ft
Malaysia
Hi all,
My first crash after 101 flights with 112.325km distance and 12 hours 39 minutes flight time.
As usual, done all the preflight check and made sure well calibrated.
10 GPS Satellites. All looked fine in GPS mode and no error, take off manually not touching the right stick.
Upon lift, at around 30cm from the ground, the aircraft veered to the left sharply and crashed into a vehicle parked 1m away.
Checked the Go4 App Flight Record, no input on the right stick. My only input was 25% on the left stick upwards to ascend. It all happened within 5 seconds.
There wasn't any error in the flight record too.
I checked for damage, just minor scratches on the SD Card cover, replaced all the props since they are damaged, recalibrate (compass and IMU), retry to take off manually and it went smoothly as expected.
What could have happened? I'm confused.
