HedgeTrimmer
One thought I will offer up on possibility of detecting magnetic interference prior to take off.
Aim nose of drone at one of compass points (North, East, South, or West) indicated by GO-4 drone on map.
To help you stay in alignment with drone, and aim your smartdevice, try picking out an object in front of drone that lays at same compass point you aimed drone at.
With your Smartdevice near drone, but not close enough to cause interference, align top of Smartdevice so it points same direction as nose of drone, and object in front of drone.
If GO-4 compass and drone on map are noticeably different, then there is a chance that there is magnetic interference. Move drone to another location and repeat.
Back away from drone 10 to 20 feet, staying in alinment with nose of drone and object you picked out. Ensure top of Smartdevice again points towards nose of drone.
If GO-4 compass and drone on map noticeably deviate, then there is a chance that there is magnetic interference. Move drone to different area and repeat.
