AlansDronePics
Flight distance : 814751 ft
Guernsey
There are several factors to consider when choosing your SD card.
Be certain the brand is not counterfeit. If you buy from the manufacturer then that will not be an issue. If you buy from a reputable source like Amazon, Check the supplier is the branded manufacturer and not Joe Blogs selling the latest, fastest SD cards. A clue might be how cheap they are. If very cheap, they may be branded rejects. Someone is always prepared to buy them and re-sell them at face value. A branded reject may work quite well for many devices but they were rejected because they failed to achieve the Class standards.
What will you use the SD card for?
If it is only for 4K video recording from your drone then the same brand and Class that came with your drone will be OK. You can decide on capacity on the basis of the notes below.
If you intend to use the SD card in other devices, like I do, then consider the needs of that device.
Note. Write speed is 2 numbers. (The slowest value and particularly relevant if you record to the card like in your drone.) A burst speed and is best ignored. Sustained speed is the speed of the card, NOT the device you might have it fitted into. For example, A Class UHS III (or 3) will not record data (video) any faster than the drone can produce it. Remember, there is circuitry between the drone camera and sd card that limit the speed data can be passed through. 60MB/sec for a mavic pro in 4K
I chose to buy a Sandisk Ultra, 64GB because it was faster than the drone needed and adequate for another device I put it in. It was the fastest around at the time for sensible money.
The write speed is also important when you send your GBs of video to your PC/MAC for processing. A fast read speed saves waiting around for the download to end. This speed is always higher than the write speed. A con by manufactures to fool the unwary.
Lastly, what capacity do you need?
Good drone practice suggests you put in a fresh chip for each flight, so 16 GB will be all you need. If the drone fails, you will still have your earlier epic footage, safe in your pocket.
No, I don't follow that wise practice. Bigger fool me. The card is 64GB and even with 4 batteries, I have never filled a card. I do have several cards in different drones.
I hope this is helpful.
For Mavic Pro and from DJI Q&A
4. What's the Mavic's maximum video bit rate?
60 Mbps.
5. How long can a video be recorded with a 16G SD card?
When recording 4K or 1080p video at 60fps and 60Mbps: 36 minutes;
When recording 2.7K video at 45Mbps: 48 minutes;
When recording 1080p video at 50/48/30fps and 40Mbps: 52 minutes;
When recording 720p video at 1080p at 25/24fps and 25Mbps: 84 minutes. |
